Create or import project
If you don’t have an Emlid account or your data isn’t visible in Emlid Flow 360, do not remove or reinstall the app, as your projects won't be saved. In case of any difficulties, please contact us at [email protected], and we'll be sure to help you out.
We recommend creating projects before the survey since some
coordinate systems
require additional downloads in Emlid Flow.
This guide describes how to create or import a project and use folders in Emlid Flow or Emlid Flow 360 to survey.
Projects are a way to group and operate your survey data. Using projects, you can collect and stake out data in the preferred
coordinate system
. Projects can be linked with a code library to help you manage survey data later in the post-processing.
Every survey starts with a project.
Creating project​
To create a project in Emlid Flow or Emlid Flow 360, follow the steps below:
  1. Go to flow360.emlid.com and sign up or sign in using your Emlid account.
    To learn how to create an Emlid account, check the Getting started guide.
  2. Click + New project on the main screen.
  3. Fill in your project info.
    If you want to create a default configuration, like the code library, coordinate system, linear and angular units for your project, check step 8.
  4. With the subscription plan, you can link a code library to your project to work with lines and codes.
    You can specify the linked code library only when creating a project.
  5. To specify the coordinate system you want to work in, click the Edit button in the Coordinate system cell.
    Check the Coordinate systems introduction to learn more.
    By default, angular units are in the DD format.
  6. Click the Create project button. Emlid Flow 360 will open the project.
  7. Open your project in Emlid Flow and ensure the coordinate system files are downloaded to your mobile device.
  8. note
    This step is optional.
    Emlid Flow 360 allows you to configure default settings for quick project setup. Go to the menu on the left and enter Workspace settings. There, you can configure default linear and angular units, add code libraries and a coordinate system, and set them as the default for future projects. After that, these settings will be applied by default when creating a new project. If needed, you can change the default configuration later. You can also edit default settings within a created project. The app will ask if you want to save the new configurations as defaults.
    If you delete a default coordinate system or code library, the projects using them will remain unchanged. However, new projects will have a default code library with points and lines, and use a global coordinate system.
Learn more about code libraries and coordinate system setup in the Manage Code Libraries, Set Up Coordinate System from Library, and Set Up Custom Coordinate System guides.
Once the project is created, you can start surveying with Emlid Flow.
Importing project data​
With Emlid Flow and Emlid Flow 360, you can import geometries and additional data, such as surface files, CAD drawings, and layers in a variety of formats. To import the project data, follow the steps below.
For step-by-step instructions on importing and managing these files, read the Working with layers, Working with CAD Drawings, and Working with Surfaces guides.
To import the project, follow the steps below:
  1. Click on the Import button on the top panel.
  2. Click the import format you want to use. The following import formats are available, each with specific requirements:
    • CAD drawings: This format supports lines, polylines, blocks, together with annotations and labels, making it well-suited for CAD-to-field workflows. Curves and splines are automatically converted to polylines during import, while layer styling is preserved. As a result, you can use the imported file as a background map and for stakeout. This format can only be imported through Emlid Flow 360.
    • DXF: This format supports points, lines, polylines, and polygons. Curves and splines are automatically converted to polylines during import, while unsupported objects, such as 3D solids, meshes, and TIN surfaces, are ignored.
    • Surface file: This format supports terrain surfaces, which are typically represented as a TIN (Triangulated Irregular Network)—a network of triangles connecting points with known elevations. The imported surface can be used for cut/fill measurements and surface stakeout in the field. This format can only be imported through Emlid Flow 360.
    • CSV: This format supports point, line, polyline, and polygon data with column headers. To import the file successfully, it must include headers such as Point, Easting, Northing, and Elevation. Additional columns are supported and imported as point attributes.
    • PENZD / PNEZD: These formats support point, line, polyline, and polygon data without column headers, making them suitable for importing geometry data from legacy surveying software. Columns must follow the required order: Point, Easting, Northing, Elevation, and Description (PENZD), or Point, Northing, Easting, Elevation, and Description (PNEZD).
    • Shapefile: This format supports points, lines, and polygons. Curves and splines are automatically converted to polylines during import. The file must be provided as a ZIP archive containing the required .shp, .shx, and .dbf files with matching names for each geometry type. During import, only the name and description attributes are preserved, while all other attributes are ignored.
    • KML Files: This format supports points, lines, and polygons.
  3. Choose the project file.
    Emlid Flow supports projects only with points and lines. Lines support is included only in the subscription plan.
  4. Wait until Emlid Flow 360 finishes importing the project. Once the project is imported, you will see the confirmation sign.
Now all the objects are imported to your project.
Setting map view presets​
Map view presets in Emlid Flow 360 allow you to define a project’s default map configuration. When you import CAD drawings or surface files and add layers, they become the active preset by default. You can later change the visibility in the object list and under the Map layers icon to change the default map view. In Emlid Flow, you can only use the default map presets set in Emlid Flow 360. You can change the view if needed, but you can’t save it as a new default.
To change the default map view preset, do as follows:
  1. After importing a new CAD or surface file or adding a new map layer, the most recent objects are visible by default. To change the view, enable or disable these objects by clicking the eye icon for the CAD files, clicking the surface icon, or choosing the layer.
    Emlid Flow 360 will keep the opacity you have saved as a default one.
  1. To go back to your initial default map view, click Reset in the upper left corner of the map. If you want to save the new map view as the default, click Save new default in the upper left corner of the map. As a result, the new default view will be shown whenever you open the particular project.
    The reset button returns the map view to the default preset. If you delete files, you cannot restore them on the map by clicking Reset.
Adding NTRIP profile​
When setting up a project, you can also add an NTRIP profile at this stage to receive NTRIP
corrections
The corrections are the data that is used to eliminate ionospheric and tropospheric delays, and satellite clock errors. The static base transmits corrections to the moving rover in the RTK scenario.
during your surveys. You can create and manage NTRIP profiles in both Emlid Flow and Emlid Flow 360, and your profiles will be synchronized between the applications.
To add a new NTRIP profile, follow these steps:
  1. Open the Emlid Flow 360 app and go to the menu on the left.
  2. Click NTRIP profiles.
  3. Click the +New button.
  4. Fill in the information from your NTRIP provider.
    To find out which mount point suits you better, check the website of your NTRIP provider. The closer the mount point, the more precise your solution will be.
  5. Click Save.
Now your new NTRIP profile is saved in your NTRIP profiles list.
Editing project​
Emlid Flow and Emlid Flow 360 allow you to modify the configuration of existing projects. Follow these steps:
  1. Click the three-dot menu for the required project in Emlid Flow 360 and click Edit.
  2. On the opened screen, change any of the following settings:
    • Name
    • Author
    • Description
    • Code library
    • Coordinate system
    • Linear units
    Learn more about editing a coordinate system in the Coordinate system setup guide.
  3. Click Save.
Working with folders​
The Folder management feature gives you the opportunity to get your and your team’s projects organised.
In Emlid Flow 360 you can create, edit, delete, and restore your folders by following the steps below:
Creating folders
To create a folder, do as follows:
  1. Open Emlid Flow 360.
  2. Click on Folder.
  3. Add a name and description to the folder. The Description field is optional.
    If you don’t name a folder, the app will automatically name it with the next incremental number. You can edit these credentials at any time from the folder by clicking Edit, or on the All projects screen by opening the three-dot menu and selecting Edit.
  4. Click on Create. Your folders will be saved on the All projects screen and sorted by creation date.
    You can’t create a folder inside another folder.
Adding project to folder
To add a project to a folder, follow the steps below:
  1. Create or import a project. If needed, configure default project settings and map view presets.
  2. On the All projects screen, open the three-dot menu for the project and click Move project.
  3. Choose the folder where you want to move your project and click Move and save.
    If you want to move your project from one folder to another, enter the folder, click on the three-dot menu, and move the project to the desired folder.
Now, your project will be in the desired folder.
A project can be in only one folder.
To remove a project from a folder, open the folder, then click on the project’s three-dot menu and select Remove from folder. The project will be listed again on the All projects screen.
Deleting folder
To delete the folder, follow the steps below:
  1. Delete the folder using one of the following ways:
    • On the All projects screen, open the folder’s three-dot menu and select Delete.
    • When you are in the folder, click the Delete icon.
    If you remove a project from a folder, it will no longer belong to that folder.
  2. If the folder contains projects, choose whether to delete both the folder and its projects or delete only the folder. The projects will be listed on the All projects screen.
The deleted folders will remain in the Recently deleted menu for 30 days. You can either restore or permanently delete them.
If you restore a project from inside the folder, the connection between the project and the folder won’t be restored. The project will be listed on the All projects screen.
Once you’ve created folders and added projects, you can continue working with them in Emlid Flow. You can navigate between folders, create projects within them, and assign a folder when creating a new project.
Checklist​
To keep your projects synced between Emlid Flow and Emlid Flow 360, double-check the following:
  • You have an Emlid account.
  • You're signed in to Emlid Flow and Emlid Flow 360 with the same Emlid account.
  • You have Internet access.
  • You're using the latest version of Emlid Flow. You can update the app from Google Play or the App Store if needed.
Further reading​
