Emlid Flow Android changelog
Changelogs include the release notes for each app version, covering new features, improvements, and bug fixes.
If you don’t have an Emlid account or your data isn’t visible in Emlid Flow 360, do not remove or reinstall the app, as your projects won't be saved. In case of any difficulties, please contact us at [email protected], and we'll be sure to help you out.
15.15 (Nov 2, 2026)​
Added
  • Faces in photo attachments are now automatically blurred before they are saved, to protect people’s privacy.
Fixed
  • Various fixes and improvements.
15.14 (Oct 19, 2026)​
Added
  • Now you can add map layers from your WMS layers library right in the mobile app.
Fixed
15.13 (Oct 12, 2026)​
Fixed
15.12 (Oct 05, 2026)​
Added
  • Now you can name projects, folders, codes, and more the way your team is used to, with longer names and more characters.
Fixed
15.11 (Sep 29, 2026)​
Added
  • Now you can import DWG files, and the CAD file size limit has been raised to 100 MB.
  • Introducing Stake elevation. Enter a design height and tolerance to see live cut and fill and know when you’re on grade — no surface needed.
15.10 (Sep 21, 2026)​
Fixed
15.9 (Sep 15, 2026)​
Fixed
15.8 (Sep 2, 2026)​
Fixed
15.7 (Sep 1, 2026)​
Fixed
15.6 (Aug 24, 2026)​
Fixed
15.5 (Aug 14, 2026)​
Fixed
15.3 (Aug 12, 2026)​
Fixed
15.2 (July 31, 2026)​
Added
  • Now you can use mobile location to see where you are in a project and get around the job site with your phone’s position.
  • Emlid Flow now supports orthometric heights for external integrations, starting with Reach RX firmware v2.11.
Fixed
15.1 (July 17, 2026)​
Added
  • Adding Emlid Corrections.
Fixed
15 (July 13, 2026)​
Fixed
14.17 (June 29, 2026)​
Added
  • See color-coded geometries on the map and get instant visual confirmation with colored points and lines right as you collect data.
Fixed
14.16 (June 19, 2026)​
Added
  • The Pro and Business tiers now have the ability to see active rovers on the project map in real time. You can enable this feature in the workspace settings via Emlid Flow 360.
  • Now you can control whether collected attributes are exported to CSV by toggling the option in the export settings.
Fixed
14.15 (June 9, 2026)​
Added
  • Exported projects in CSV, KML and Shapefile formats now include information about authorship.
  • Added a new screen to view all photos of a given geometry with the ability to navigate to a single photo.
Changed
  • Meet the refreshed receiver list, updated app permissions with clearer logic, and a polished NTRIP configuration flow on the Correction input screen.
Fixed
14.14 (May 29, 2026)​
Added
  • Now, you can define custom attributes for point and line codes in Emlid Flow 360, then fill in additional information about objects you collect in a structured way in the mobile app.
  • Emlid Flow now supports orthometric heights for external integrations, starting with Reach RX2 firmware v2.10.
Fixed
14.13 (May 8, 2026)​
Fixed
14.12 (April 28, 2026)​
Fixed
14.11 (April 17, 2026)​
Added
  • Now, you can link photos to points for as-builts and other documentation.
14.10 (April 2, 2026)​
Added
  • When tapping where multiple objects overlap on the map, a picker now appears so you can choose the exact point, line, or surface you need.
  • Added new coordinate systems and vertical datums for Germany, Estonia, New Caledonia, Martinique, Réunion, and French Antilles.
  • We are pleased to present Danish and Dutch language support!
Fixes
14.9 (March 23, 2026)​
Fixed
14.8 (March 6, 2026)​
Added
  • Added Georgian localization for a smoother experience for Georgian-speaking teams.
Fixed
14.7 (Feb 25, 2026)​
Added
  • Line stakeout modes To line and By segments are now available in AR.
  • Folder management is now available in Emlid Flow 360. Organize your team’s projects and structure complex workflows, then access and work with them seamlessly in the mobile app.
Fixed
14.6 (Feb 9, 2026)​
Added
  • Now you can stake out lines with intervals and offsets in AR.
Fixed
14.5 (Jan 26, 2026)​
Added
  • Added multiple new coordinate systems and vertical datums for Albania, Canada, Germany, Greenland, Indonesia, Saudi Arabia, South Korea, Sweden, and others.
Fixed
Changed
  • “Romania MN75 height” updated to “RomHybQGeoid2025.05".
Removed
  • Removed deprecated legacy coordinate systems with known issues.
14.4 (January 13, 2026)​
Fixed
  • Minor fixes and visual improvements.
14.3 (Dec 18, 2025)​
Fixed
14.2 (Dec 8, 2025)​
Fixed
14.1 (Dec 4, 2025)​
Fixed
14 (Dec 2, 2025)​
Added
  • The Survey plan has been renamed to Pro. All existing subscribers keep full access to paid features.
  • Added support for new team collaboration features.
Fixed
13.18 (Nov 26, 2025)​
Fixed
13.17 (Nov 10, 2025)​
Fixed
13.16 (Nov 10, 2025)​
Added
  • Now you can edit your profile name right in the app.
  • Explore survey features more easily with Virtual Reach. Just enable the receiver in Profile tab > Settings > App settings and connect to it in the Receivers tab.
  • Other improvements for the Profile tab: you can find all app-related settings, such as app version, receiver analytics, and troubleshooting reports, in a separate section, Settings > App settings.
Fixed
13.15 (Oct 29, 2025)​
Added
  • Save visibility for CAD, DTM, and WMS layer opacity as a map preset and it will be automatically synced across all your devices. Tweak settings anytime and tap Reset to return to your saved view.
  • We simplified project setup: instead of settings scattered across screens, there’s now a single, consistent workspace configuration. Set it once and new projects (and related screens) will use your defaults. You can still override any option when creating a new project. As part of this change, angular units will be reset once. Reapply your preferred units in Settings → Workspace settings.
Fixed
13.14 (Oct 1, 2025)​
Added
  • To improve the experience of navigating the map out in the field, we are making the satellite map style available on the free tier of Emlid Flow!
  • We refreshed the app’s look and feel to align with Emlid’s new brand system.
Fixed
13.13 (Sep 15, 2025)​
Fixed
13.12 (Sep 11, 2025)​
Fixed
13.11 (Sep 5, 2025)​
Fixed
13.10 (August 22, 2025)​
Added
  • Exported CSV files now include additional information: receiver’s model and serial number for collected points and descriptions for survey codes.
Fixed
13.9 (August 12, 2025)​
Fixed
13.8 (July 27, 2025)​
Added
  • The Inverse tool and the line info view now display the angle value for three-point lines.
  • We are pleased to present Swedish language support!
Removed
  • The Turkish localization is no longer available in the app.
Fixed
13.7 (July, 11 2025)​
Fixed
13.6 (June 27, 2025)​
Added
  • The ability to calculate the distance and direction by two points has been added in Intersection, similar to the functionality in Traverse.
Fixed
13.5 (June 16, 2025)​
Added
  • We are introducing the Intersection functionality! The new tool lets you calculate a point at the intersection of distances or directions from two known points.
  • With this update, the app can keep the BLE connection and the “NTRIP over Bluetooth” corrections stream active while running in the background. On Android 13 and newer, notification permission is required by the system to allow the background service to work.
  • Survey plan users can now stake out lines at specified intervals, with the option to apply horizontal and vertical offsets. Just select a line, start stakeout, tap the mode name, and switch to “By intervals & offsets”.
Fixed
13.3 (June 02, 2025)​
Fixed
13.2 (May 26, 2025)​
Fixed
13 (May 6, 2025)​
Added
  • Update Emlid Flow to version 13 to keep your projects synced with the cloud and accessible via your Emlid Account. In a few months, new data collected with older app versions will no longer be accessible in Emlid Flow 360 and other devices.
12.2 (Apr 23, 2025)​
Added
  • You can now configure format settings before exporting a project.
  • Added new coordinate systems for Jamaica, Costa Rica, Turkey, and the Netherlands, as well as the “JPGEO2024” geoid for Japan.
12.1 (Apr 2, 2025)​
Added
  • Now, when you work with CAD drawings, you can select line vertices right from the map. Additionally, points from the drawing are visible and can also be selected.
  • Line stakeout now lets you track the distance along the entire line without having to manually switch between segments.
12 (Mar 19, 2025)​
Added
  • Emlid Flow now allows you to upload your CAD designs for set-out or as-built. It keeps the drawings the way they were created: retaining the geometry view, colours and annotations. You can stake out objects from the plan or simply use it as a background.
  • The Traverse tool now supports calculating 2D distance and direction by selecting two existing points instead of entering an exact value.
  • Added support for “Transverse Mercator (South Oriented)” projection type, so now “Hartebeesthoek94" CS works correctly.
  • Introduced additional CSs for South Africa and Namibia: “Cape” and “Schwarzeck”.
Fixed
11.12 (Feb 25, 2025)​
Added
  • Reach receivers can now be updated directly through the Emlid Flow app.
11.11 (13 Feb, 2025)​
Added
  • You can now export and import data in PNEZD CSV format.
Fixed
11.10 (Jan 31, 2025)​
Added
  • Meet the updated Wi-Fi settings screen! Connecting to networks is now easier and more convenient with the improved user interface.
  • Updated and additional coordinate systems were introduced for Singapore, Norway, and Bonaire Island. This update also includes an option to use the beta version of the latest “GSIGEO2024” geoid in Japan.
  • Starting with firmware 31.6 you can use Bluetooth to connect to your Reach. This feature is in the beta stage.
Fixed
11.9 (Jan 17, 2025)​
Fixed
11.8 (Dec 18, 2024)​
Added
  • The app now has a refreshed design! Enjoy a cleaner, more modern interface with improved usability for an even better experience.
  • Starting with firmware version 1.6, you can update Reach RX receivers directly from the Emlid Flow app.
11.7 (Nov 23, 2024)​
Added
  • We added support for US coordinate systems using feet and US survey feet units, enhanced the GCVerticalAdjustment with a UOM property, and implemented 13 new vertical datums for New Zealand's regional height systems. Additionally, we introduced datum transformation between GDA2020 and AGD84 for Australian coordinate systems, improving compatibility with AGD84-based systems.
  • Added the ability to edit a point’s coordinates by duplicating it, making it easy to correct errors from faulty data imports or mistakes made during point creation.
11.6 (Nov 07, 2024)​
Added
  • With this update, you can change the linear unit of your projects even after creation. Additionally, the status overview screen now includes a switch for the linear unit, enabling you to view data in feet.
Fixed
11.5 (Oct 26, 2024)​
Fixed
11.4 (Oct 10, 2024)​
Fixed
11.3 (Sep 20, 2024)​
Added
  • Additional coordinate systems were introduced for Australia, Puerto Rico, the USA, the Philippines, Latvia, the Bailiwick of Guernsey, and the Bailiwick of Jersey.
  • Meet the offset configuration for DTM! To set a temporary vertical offset, enter the desired value (up or down) in the survey settings. This feature allows you to work with one DTM file at different stages of a project.
  • Enabled the ability to collect points during surface stakeout. Please note that currently, measured points will not include delta information and will not be added to the stakeout report.
  • The line and point stakeout over DTM has been improved. You can now simultaneously view cut/fill values from your current position to the DTM and to the elevation of a point or line.
  • The app now supports polygon geometries! You can collect polygons on the go or create them from previously collected points and lines, streamlining boundary definition for faster and more efficient results.
Fixed
  • Minor fixes and improvements.
11.2 (Aug 23, 2024)​
Added
  • Now you can key in pre-calculated localization parameters while creating a custom coordinate system.
Fixed
11.1 (Aug 06, 2024)​
Fixed
11 (Jul 31, 2024)​
Added
  • We are excited to introduce surface stakeout in the Emlid Flow app! You can now upload DTM files in LandXML format and get cut and fill values during surface stakeout. Additionally, cut and fill values are calculated from surface elevation during points and lines stakeout.
10.9 (Jul 04, 2024)​
Added
  • Added the ability to select the preferred angle display format: DD or DMS.
  • This update includes enhancements to the data safety mechanism. It is highly recommended to install this update.
  • You can now receive product-related announcements via the in-app newsletter. To check out the latest news, go to Profile > What's new.
10.8 (Jun 18, 2024)​
Added
  • We are pleased to present Japanese language support!
Fixed
10.7 (Jun 05, 2024)​
Fixed
10.6 (May 28, 2024)​
Added
  • The Traverse tool now allows you to enter azimuth in the DMS format.
  • You can now select line codes when creating or editing a single point.
  • We're excited to announce that the Survey plan now includes Auto collection mode. This feature allows you to automatically collect points and lines at specified time or distance intervals. To set up this mode, go to the Survey settings under the gear icon in the Collector tool.
Fixed
10.5 (May 07, 2024)
Fixed
10.4 (Apr 23, 2024)​
Added
  • We are pleased to present Czech language support!
  • Information about collected points is extended to include GDOP, NTRIP mountpoint info, and the number of satellites for each constellation.
  • The inverse tool now visualizes enclosed area.
Fixed
10.3 (Apr 09, 2024)​
Added
  • We updated the Collector tool with the “Precision limit” setting! Now you have more control over the quality of the data you collect. This new feature is available in both Free and Survey plans.
  • Emlid Flow now supports import and export of projects in KML format.
10.2 (Apr 02, 2024)​
Added
  • We are introducing the Inverse and Traverse functionality! Now, you can use the Inverse tool to view information about the selected points (area, slope distance, 2D distance, etc.). The Traverse tool lets you calculate a new point based on an existing point and the distance, azimuth, and elevation difference you enter.
10.1 (Mar 20, 2024)​
Added
  • The Collector tool now allows to select on which side of the line you want to collect a new point.
Fixed
10 (Mar 06, 2024)​
Added
  • We are introducing the Stakeout report feature. Now you can save points directly from stakeout mode and export the coordinate deltas as a CSV report.
Fixed
9.12 (Feb 13, 2024)​
Added
  • The Line Info screen now provides more information about each segment of a line.
Fixed
9.11 (Feb 01, 2024)​
Added
  • Added the possibility to create/edit lines by selecting points on the map or from the list of project objects.
9.10 (Jan 15, 2024)​
Added
  • The stakeout tool now displays the azimuth value. The azimuth value is a measure of the direction from a rover to a target in point stakeout, and to an intersection point in “To line” mode.
  • You can now select and view point and line information directly from the collect and stakeout modes.
Fixed
9.9 (Dec 21, 2023)​
Added
  • The Line Info screen now provides more information, including area, perimeter, direction, grade, and more. The information depends on the number of points in the line.
  • We are introducing a new Stakeout mode! Now the map automatically rotates so you can quickly find your position relative to a point or line. The old Stakeout mode is available by tapping the Follow button on the map.
Fixed
9.8 (Dec 12, 2023)​
Added
  • Survey plan subscribers can now export CSV files with a custom format. The file configuration is taken from Emlid Flow 360.
Fixed
9.7 (Nov 28, 2023)​
Added
  • You can now get instant logging feedback right from the status bar and more detailed information from the status overview. In addition, the process of starting and stopping logging is more accessible through the integration of native logging controls.
Fixed
9.6 (Nov 14, 2023)​
Added
  • With this update, projects with a projection will use grid distances in the calculations. Projects in the Global coordinate system will use ground distances.
  • We updated the formatting of distances in the Stakeout tool and line info screen. The new format provides centimeter-level accuracy even for long distances.
9.5 (Oct 31, 2023)​
Added
  • Added new coordinate systems for Ireland, Germany, and Hong Kong.
  • Updated the geoid used for “DVR90 height” to a newer version.
Fixed
9.4 (Oct 18, 2023)​
Fixed
9.3 (Oct 5, 2023)​
Added
  • The “FIX only” option is now available for the Stakeout tool. When turned on, the setting will also show a notification in the status bar, highlighting insufficient conditions.
  • We updated the Profile section of the app. You can now find the link for documentation for every Emlid receiver and software product. The offline PDF docs are also available for download at the bottom of the documentation page.
Fixed
9.2​
Fixed
9.1​
Added
  • Added a bunch of WGS84-based projections for India.
  • Added a new vertical datum was introduced for high-precision measurements in Bucharest, Romania—“Bucharest-Ilfov MN75 height”.
  • The UTM zones 34N and 35N of the ETRS89 datum are now available for Romania.
  • The “Romania MN75 height” was renamed to “MN75 height” and updated and now it uses the latest version of the geoid: “EGG97_QGRJ_2023.tif”.
Fixed
  • The missing option to switch on RS/RS+ through the bottom connector in the settings list has been put back in place.
9​
Added
  • We are pleased to introduce a major update of the Survey plan—Localization. With this new feature you can calibrate your work site to fit existing control points for better precision.
Fixed
8.11​
Fixed
8.10​
Added
  • We added new “ETRS89” to “MGI” transformation that uses the updated 2021 version of the “AT_GIS_GRID” grid. “ILUM2 height” for Israel was also added.
Fixed
8.9​
Added
  • You can now search the lists of projects and NTRIP profiles.
Fixed
8.8​
Added
  • We added support for South African CRSs based on the “Hartebeesthoek94” datum. The South African vertical datum “SAGEOID2010” was also added.
  • You can now search your projects list.
Fixed
8.7​
Added
  • CSV(PENZD) import format added.
  • We added new vertical datums for Thailand (Kolak-1915 height) and Italy (Genoa 1942(South Tirol) height). Support for Israeli CRSs (Israeli Grid 05/12, Israeli Grid 05) has also been added.
  • Added support for Chilean CRSs: “SIRGAS-2021”, “SIRGAS-16” and “REDGEOMIN” horizontal datums as well as projections based on these datums and “GEOID2021” and “EIGEN-6C4” heights with corresponding geoids.
Fixed
8.6​
Fixed
8.5​
Added
  • Survey plan users can now change points' codes. That includes older data created before coding was introduced to Emlid Flow. Note that this update also fixes the ordering of objects when exporting or importing data.
  • Meet the updated object list in the project view! Check out the improved search logic and redesigned display of lines' contents.
8.4​
Fixed
  • Exported DXF files now have a new layer with survey codes.
8.3​
Added
  • Survey plan users can now change a project's code library. That includes older data, created before coding was introduced to Emlid Flow.
  • Survey plan subscribers can now add WMS layers to the map for better context and navigation.
8.2​
Changed
  • Field names of exported shapefiles were changed slightly to achieve better compatibility with third-party software.
Fixed
8.1​
Fixed
8​
Added
  • ReachView 3 is now Emlid Flow! The new app includes professional survey features. Collect and stake out points and lines, perform stakeout with offset and chainage. Use our code library or upload your own to collect data faster. Use a satellite map view for more context.
7.15​
Added
  • The NTRIP over Bluetooth option now works correctly with NTRIP services that use TLS protocol.
7.14​
Fixed
7.13​
Fixed
7.12​
Added
  • You can now control the quality of satellites’ signals by checking the SNR values on the Status screen.
7.11​
Added
  • Non-web-based interface that allows renaming the connected receiver.
7.10​
Added
  • Redesigned receiver Settings view. The most frequently used settings are now on the Receivers screen when Reach is connected. The Settings screen is rearranged and unnecessary nesting of views is eliminated.
7.9​
Added
  • ReachView 3 shows the total distance value next to the rover icon on the map during the stakeout process.
  • It is possible to scroll the buttons above the Collector tool to the right to check the real-time coordinates of the receiver during the data collection process.
Fixed
7.8​
Fixed
7.7​
Added
  • A list of verified coordinate systems which are searchable by country, name, and EPSG codes. Corresponding systems from the EPSG registry are marked as legacy, but still available.
  • Redesigned Stakeout and Collector tools. The map in the new Stakeout is always oriented towards North. The ground distance is split by North-South and East-West axes. The new Collector is more compact so you can see a larger part of the map, and the new color scheme making the interface more visible in bright sunlight. The tool has the new Measure button to ease the collection process.
  • It is now possible to request account deletion.
Fixed
7.6​
Added
  • Slovak language localization.
Fixed
7.5​
Added
  • There is a new visual improvement of the stakeout tool: when you get closer than 40&nbspcm (1.312&nbspft) to a point, you can match the point and the rover more easily.
Fixed
  • Improved the stability of the receivers scanner.
7.4​
Added
  • It is now possible to enter a base’s position or points’ coordinates in the DMS format.
  • Added the datum transformations from “ETRS89” to “S-JTSK (Ferro)” and “S-JTSK [JTSK03]” for Slovakia, and from “ETRS89” to “Albanian 1989” for Albania.
  • There is a new “NTF / Lambert Corse” coordinate system support.
Fixed
7.3​
Added
  • You can now set project points as base position. That enables you to add a survey marker position to a project as a point, then use this point to set up your base.
Fixed
7.2​
Fixed
7.1​
Added
  • We added new vertical datums for Columbia (Colombia GeoCol2004 height) and Azores Islands (Portugal GEODAZ2014 height).
Fixed
7​
Added
  • We are happy to introduce the next major update for the app—Cloud sync! Log into your Emlid Account and store your projects, coordinate systems, and NTRIP profiles in cloud storage. No longer worry about losing data if the hardware fails; work with multiple mobile devices with ease! The app will sync your work every time it has access to the Internet without requiring a persistent connection.
  • The app now supports exporting Shapefiles with global coordinates.
Fixed
6.17​
Added
  • When connected to a receiver, you can now change its Bluetooth settings and manage its paired devices.
Fixed
6.16​
Added
  • We added the ability to delete custom coordinate systems.
Changed
  • The app now shows more verbose warning messages if there is an issue with NTRIP credentials or the selected mountpoint.
Fixed
6.15​
Added
  • Exported CSV files now have additional columns containing geographic coordinates of the base.
Fixed
6.14​
Added
  • We added the ability to edit the name and description of existing survey projects.
  • ReachView 3 now supports DXF export with the point name and height as text objects.
  • The collector tool now makes a sound upon successful point collection.
  • Added a new option for the Correction output—“Local NTRIP.”
Fixed
6.13​
Added
  • Exported CSV files now have an additional column containing the name of the coordinate system.
  • Added the new transformation from RGF93 to NTF used for all CRSs based on NTF datum. These systems now require grid downloading.
  • When connected to a receiver, you can now check its Firmware version and available updates from inside the app.
Fixed
6.12​
Added
  • Added the datum transformation from ETRS89 to Belge 1972, used in Belgium.
  • There are new vertical datums: “Brazil hgeoHNOR2020 height”, “South Africa SAGEOID2010 height”, and “Belgium HBG18 height”.
  • Added two vertical datums for France: “NGF-IGN69(RAF18B) height” and “NGF-IGN69(RAF20) height”.
Changed
  • We increased the maximum collection time to 60 minutes.
  • Coordinate systems without a projection are discontinued. This kind of systems has been removed from the list, and you can no longer create custom coordinate systems without specifying a projection. If you want to work in degrees, you may use the new Global CS option.
  • Position accuracy is now shown at all times, not just when averaging.
Fixed
  • Fixed a rare case that could lead to the rover and base icons missing from the map.
  • Fixed an issue that could lead to degraded performance of the collector tool while using a high update rate in GNSS settings.
6.11​
Fixed
6.10​
Added
  • Added support for French, Norwegian, Polish, and Portuguese locales.
Fixed
6.9​
Added
  • ReachView 3 now supports import and export of projects in Shapefile and DXF formats.
Fixed
6.8​
Added
  • Now, you can restore settings of your Reach from the app! To do this, select a corresponding menu item in the general settings section of your connected device.
  • Meet the new base shift feature, which allows applying a real-time shift to rover and base coordinates. To do this, open the corresponding wizard from the project info bottom sheet and select measured and known points.
Changed
  • Now, devices with a Firmware version lower than 26 need to be updated to work with ReachView 3.
Fixed
6.7​
Added
  • We present you the ability to add points to a project by manually entering coordinates! While in the project, head to the points list, where you can now find a new control to add a point.
Fixed
6.6​
Added
  • Add new vertical CRSs for South Korea: “KNGEOID13 height”, “KNGEOID14 height”, and “KNGEOID18 height”.
  • Added required transformations to ensure correct work of the surveying features on Hawaii.
  • Meet the updated Base mode settings screen! Configure automatic base position averaging or enter exact geographic coordinates manually using the new UI.
Fixed
  • Fix the 7-parameter transformation for the GGRS87 system (Greece) to work as expected.
6.5​
Fixed
6.4​
Added
  • Now, you can restart and shut down your Reach from the app! To do this, tap on the connected device on the scanner or device settings screen and select a corresponding menu item.
Fixed
  • Fixed an issue that could change points’ coordinates upon import if the project uses a custom CRS with Molodensky-Badekas transformation. If you encountered such behavior, we recommend creating a new project.
6.3​
Added
  • Added an ability to check base coordinates in the point info bottom sheet.
  • Added new vertical datum, “Greece GREEKGEOID2010 height”, used in Greece.
  • There are new horizontal CRSs for Greece: “HTRS07”, “HTRS07 / TM07”, “GGRS87”, and “GGRS87 / HEPOS”.
  • Added a new “Baltic 1977 height” vertical datum for Georgia.
Fixed
6.2​
Fixed
6.1​
Fixed
6​
Added
  • We are proud to present the next major update of the app. Starting with this version, it is now possible to create custom coordinate systems by entering all needed parameters. To test the new functionality, head to the list of coordinate systems and hit the “plus” button.
  • We now support a new vertical datum, “Italy ITG2009 height”.
Changed
  • All projects in Italy that use CRSs based on ED50 datum will utilize the transformation from ETRS89 to ED50 by “italy_ed50.tif” horizontal grid.
  • All projects in Italy that use CRSs based on Monte Mario datum will utilize the transformation from ETRS89 to Monte Mario by “roma40.tif” horizontal grid.
Fixed
5.10​
Fixed
5.9​
Added
  • Starting with Reach Firmware version 26, the app will save the highest PDOP value received during point collection. These values will be available in exported CSV files.
Fixed
5.8​
Added
  • Now, you can copy point coordinates and CRS info from the project's bottom sheets with a long tap on them.
  • The Swiss vertical CRS “LHN95 height” is available once again! Be advised that projects created before the system’s temporary removal will ask you to re-download the geoid file.
  • There is a new vertical datum “LN02 height” for Switzerland.
Changed
  • Update metadata for a bunch of geoid files. It will affect projects based on “SRVN16 height”, “Latvia 2000 height”, “NN2000 height”, and “N60 height” vertical datums. Existing projects that use these vertical datums will ask you to re-download updated files upon opening.
Fixed
5.7​
Fixed
5.6​
Added
  • The vertical CRS “DHHN2016 height” used in Germany is back! Please note that projects created before the system's temporary removal will ask you to re-download the geoid file.
  • There are two new vertical datums for Hungary: “Hungary VITEL2014 height” and “Hungary EHT2014 height”.
  • Added the transformation from ETRS89 to HD72 by “etrs2eov” horizontal grid, used in Hungary. Now, all CRSs based on HD72 datum will utilize this transformation.
Changed
  • Updated distance formatting in the stakeout tool to make precise measurements over long distances easier.
Fixed
5.5​
Added
  • The averaging timestamps in exported CSV now contain a time zone offset. This will help to preserve information when importing a project in a different time zone.
  • The EPSG list was updated in accordance with the EPSG v10.003.
  • There are two new vertical datums for Croatia ("HVRS71 height") and France ("NGF-IGN69(RAF09) height").
Fixed
5.4​
Added
  • Exported CSV files now also contain geographic coordinates of points.
Fixed
  • Fixed an issue that could cause the app to break the order of imported points randomly.
5.3​
Changed
  • Updated Russian, Spanish, and Turkish translations.
  • Minor visual updates.
5.2​
Added
  • We added new vertical CRSs to support the legacy "GEOID12B" geoid. It covers the CONUS area and Alaska "NAVD88(GEOID12B) height", Virgin Island "VIVD09(GEOID12B) height" and Puerto Rico "PRVD02(GEOID12B) height".
Changed
  • The status overview now shows the PDOP value with one decimal place.
  • Slightly updated fonts in the status overview to make values more readable.
5.1​
Added
  • Correction output settings will now notify you if LoRa requires a higher air data rate. This feature covers the case when you enable LoRa, but the set air date rate doesn't suffice for configured RTCM3 messages. In such a case, the app will prompt you with a dialog describing the situation.
  • The correction input settings screen and the status overview drawer will now show if your device is receiving corrections.
Changed
5 Beta​
Added
  • Added a view with device status data! Coordinates, solution status, DOP, info about corrections, you name it. You can access the device status overview page anywhere in the app by tapping on the status bar.
  • The last piece of correction output settings is here – the NTRIP option is now unlocked.
  • Added new vertical CRSs for Argentina and Brazil.
  • General settings are now fully unlocked. "Firmware updates" and "Device and hotspot name" are accessible via the web interface, starting with the 2.24.1 firmware version.
  • Notification about new Reach firmware update has been added to the device settings screen, so you do not miss out on new functionality.
Changed
  • Updated the grid required by "Romania MN75 height" CRS as the previous version caused incorrect height transformations. Existing projects won't be affected, but you'll need to download the new file. Be advised that exported CSVs are prone to have erroneous height values.
  • Now, devices with a firmware version lower than 2.24.0 need to be updated to work with ReachView 3.
  • The device scanner now shows more verbose errors and allows you to do the first setup or update receivers directly from the app.
Fixed
Removed
  • Removed CRSs "DHHN2016 height" and "LHN95 height" due to license issues. Existing projects will continue to work correctly, but you will be unable to use said systems for the new ones.
4.15 Beta​
Added
  • Added quick access to the Base mode settings via the web interface.
  • Mobile data, Wi-Fi, Bluetooth, and Camera control now display their statuses on the main settings screen.
  • We added new vertical CRSs for Slovenia, Continental Portugal, Mexico, Lithuania, and Romania.
4.14 Beta​
Added
  • LoRa configuration is now editable in correction output settings.
  • We added a new vertical CRS "Latvia 2000 height" along with "lv_14.tif" geoid, which covers all Latvia areas.
  • Added quick links to configure mobile data, Wi-Fi, Bluetooth, and GNSS settings via the web interface.
  • You can now access the web-based logging page from the Receives tab! We tweaked a few things, and downloaded logs now can be shared using the native Android interface.
Changed
  • From now on, Serial wizard won't let to apply conflicting settings.
Fixed
  • We fixed a tricky case when our CSV exporter might have been confused by users switching between projects with different CRSs. Points' coordinates will no longer be exported with the wrong number of digits after the decimal point.
4.13 Beta​
Added
  • Survey project wizard became smarter, and now it remembers the last used CRS setup.
Changed
  • We made the map reading easier by adding a scale bar to it.
  • Now, map controls are non-transparent so that underlying content won't interfere with their content's visibility.
  • A small yet useful update for the point info: we moved the point editing button to the top. You'll no longer need to drag the bottom sheet up and down — all essential controls will be near at hand.
Fixed
4.12 Beta​
Added
  • Serial and Bluetooth configurations are now editable in position streaming settings.
  • We added support for a bunch of new vertical coordinate systems! This update includes CRSs for Austria, New Caledonia, Balearic Islands, Canary Islands, Ceuta, Alicante, and Slovakia.
  • The correction output settings are here! At the moment, we have TCP and Serial wizards available, with others coming in the future updates.
Changed
  • Now, when you create or edit a project, NTRIP profile, or point, text fields won't contain accidentally entered leading and trailing whitespaces or empty lines.
  • We changed the default base CRS for some coordinate systems used in New Caledonia, Slovakia, and Romania.
Removed
  • The EPSG list was updated in accordance with the EPSG v9.8.12 and ESRI v10.8.1.
4.11 Beta​
Added
  • Now it is possible to edit LoRa configuration in correction input settings.
  • TCP configuration is now editable in position streaming settings.
  • The input field in the antenna wizard become smarter! When you tap on it, all text inside will be highlighted to make it easier to enter a new value.
  • The Troubleshooting and System report sections are now available from the General device settings.
Changed
  • Now, the map zoom level will remain the same when you select a point from the list.
Fixed
  • We fixed an issue that could cause random reordering of points when exporting a project as CSV. Such behavior seems to appear while working with data collected before the 4.10 update. Be advised that CSV files created by the previous app version are prone to have points reordered.
4.10 Beta​
Added
  • Now it is possible to configure position streaming settings (editing channels is not yet available).
  • Added a delete point button to the point info bottom sheet for better convenience.
  • Now, the project map shows the position of the base if it's available.
  • Added support for Italian locale.
Fixed
  • We fixed an issue that caused the collector tool to not save the base position and the baseline when averaging is off.
4.9 Beta​
Added
  • We've added new experimental vertical CRS "DHHN2016 height" along with "CGC2016.tif" geoid, which covers almost all Germany areas. Exact coordinates of coverage area: from 47.225° to 50.6° in latitude, from 7.426° to 13.9° in longitude.
  • Project import and export were upgraded to support base position and baseline. These values can be imported (and exported) using the following headers: Base easting, Base northing, Base elevation, and Baseline.
Changed
  • App fonts have been updated to make things uniform and less prone to layout-related issues.
Fixed
  • We fixed an issue that caused the collector tool to save incorrect antenna height values (they are off by up to 1 foot). This issue affected projects with CRSs which use feet, U.S. survey feet, or Gold Coast feet and did not affect point height values. Be advised that collected points are prone to have erroneous antenna height data.
  • Earlier, when exporting a project whose target CRS uses imperial units, the antenna height and RMS values were saved in meters, which is not correct. Now, these values will be represented in measuring units corresponding to the project target CRS.
  • Fixed multiple cases of keyboard overlapping UI elements, making app content inaccessible.
4.8 Beta​
Added
  • Now the app will notify you about updates containing major changes.
  • Tune-up your Reach RS2 devices with the Sound settings, which are now unlocked! Check the improved UI and UX – it will even notify you if the Night mode already suppresses the sound.
Changed
Fixed
4.7 Beta​
Added
  • Added a new notification to NTRIP profiles manager in the Profile tab. If you create or edit an NTRIP profile, and any Reach is connected at that moment, the app will now ask you if you want to change settings on that Reach.
  • Added new coordinate systems for Ghana and Sierra Leone (ones which use Gold Coast Foot unit of measure).
Changed
  • We now use a different way to calculate accuracy estimates. The RMS numbers you see will be slightly higher, but they will also be more realistic.
  • Points of the project are now muted when the collector tool is active.
  • Now devices with a firmware version lower than DEV 2.23.8 need to be updated to work with ReachView 3.
Fixed
  • Fixed the correction input settings screen, which was failing to display current LoRa parameters.
Removed
  • Due to technical issues, we had to remove multiple CRSs based on a non-EPSG geographic coordinate system.
4.6 Beta​
Added
  • There's a new loading indicator during search in the coordinate system picker.
  • Project import was upgraded to support point metadata, like solution status and antenna height. Here's a full list of supported headers: Easting RMS, Northing RMS, Elevation RMS, Lateral RMS, Antenna Height, Solution Status, Averaging Start, Averaging End, Samples.
  • Now all geoid and grids use .tif format instead of .gtx and .gsb. Previously created projects may ask to re-download grid/geoid files. Sorry for the inconvenience.
  • Update the EPSG systems list in accordance with the EPSG v9.8.9.
  • Add new vertical CRSs: EPSG:5709(NAP height), EPSG:3900(N2000 height), EPSG:5717(N60 height).
  • Add new experimental vertical CRSs: EPSG:5621(EVRF2007 height) (along with "ugik-geoid2011-PL-EVRF2007-NH" geoid, used in Poland), EPSG:5729(LHN95 height) (along with "CHGEO04A" geoid, used in Swiss).
  • Change default base CRS for all projected and compound CRSs based on geographic "CH1903+" and "DHDN" to "ETRS89".
  • The Receivers tab now offers some hints on how to find your Reach if it's not on the list.
Changed
  • Now devices with a firmware version lower than DEV 2.23.7 need to be updated to work with ReachView 3.
Fixed
  • Now the countdown in the point collection tool saves its mode (passed or remaining time).
  • In some cases, projects with non-default vertical CRS could have been exported incorrectly. Now it is fixed.
4.5 Beta​
Added
  • Now it is possible to edit TCP and Serial settings in correction input.
  • We've added some protection against accidental cancels during point connection. If averaging time is more than 10 seconds, cancelling the collection must be confirmed by additionally tapping a new stop button.
  • Now the point collection tool shows a countdown. By tapping on it you can switch countdown mode between how much time has passed and how much time has left.
Changed
  • Increased the pole height input font size, to make it more readable.
Fixed
  • Now stakeout tool displays long point names properly.
  • Various fixes to ensure app stability.
4.4 Beta​
Changed
  • EPSG:4289 Amersfoort is back in CRS list and available to be used for project creation. Due to the ongoing process of grid support development, this CRS will use default transformation with assured accuracy of 0.5  m.
Fixed
  • Fixed internal issue that resulted in a crash when a project with a custom compound coordinate system was created.
4.3 Beta​
Added
  • NTRIP profile wizard in the 3rd tab now has a hint about the mount points list. This little update should clarify the fact that the automatic mount points loading is currently accessible only via Correction input settings
  • Added support for Turkish locale.
  • Added new CRSs for the UK: EPSG:5701(ODN height) vertical datum and EPSG:7405(OSGB 1936 / British National Grid + ODN height) compound CRS.
Changed
  • Serial ports now have correct names according to the type of connected receiver.
  • The collector tool now reuses the description of the last collected point for a new one. You still will be able to clear it via the Edit dialog.
  • EPSG:4289 Amersfoort was disabled for project creation due to internal technical issues. Existing projects will still be intact, but there is a high risk of collected data being unreliable.
  • Improved the search engine in the project creation wizard’s CRS list. You will now receive more accurate results while searching for a CRS by a part of its name/code.
Fixed
  • Fixed the Receiver section in the antenna height wizard to always show a correct device model.
  • Minor fixes and stability improvements.
  • Fixed height transformation for systems based on EPSG:4617(NAD83(CSRS)) geographic CRS with EPSG:6647(CGVD2013(CGG2013) height) or EPSG:9245(CGVD2013(CGG2013a) height) vertical datum.
4.2 Beta​
Fixed
  • Unfortunately, in some cases, the application crashed when entering the receiver's settings menu, now this problem has been solved.
  • When creating or modifying an NTRIP profile, the already selected mount point will be displayed as selected in the list, as well as automatically scrolled to its position.
4.1 Beta​
Added
  • When you create an NTRIP profile, you will automatically receive a list of mount points provided by your caster.
  • Now, on the third tab, you can modify existing NTRIP profiles and create new ones even if the receiver is not connected.
  • Added "FIX only" setting that allows point collection only with FIX solution.
Changed
  • If the rover icon is not shown on the map, the "Follow" button now will be disabled as well.
  • Updated the connected device's menu by renaming Settings into ReachView 2. Such naming should make clear what settings we refer to in the different parts of the app.
  • Now the third tab has been renamed to "Profile".
  • Norway vertical datum EPSG:5941(NN2000 height) became available, unlocking a bunch of compound CRSs.
  • Broaden ranges of available vertical datums for multiple horizontal CRSs.
  • Add Russian and Spanish translations for more strings.
Fixed
  • Fixed a bug that might have caused an appearance of negative zero coordinates in the point info and the collector.
  • Fix the hint for the Night mode switch on the Settings screen. Text now will be relevant for a connected receiver – we shouldn’t promise muted sound for non-RS2 devices.
  • Fixed some views that were ignoring the Android system Back button.
  • Since the previous coordinate system for the demo project required to download additional data, we replaced it with a similar one.
  • Selecting two coordinate systems from the list simultaneously could lead to incorrect behavior. This has been fixed.
  • Fixed potential app crashes that may be caused by CSV import. Unfortunately, we can no longer guarantee the compatibility with the ES File Explorer app, whose way of opening files differs from what we expect.
4 Beta​
Added
  • Now, the application will remind you if the phone’s Wi-Fi is not enabled when you are trying to scan for available receivers.
Changed
  • Notifications about Reach firmware updates have been improved. If Reach is on Stable, the application will ask you to enable Dev and update. If you are already on Dev, you can simply upgrade to the latest version.
  • Fixed UI glitches that might be caused by a receiver connection error.
  • Updated the look of the rover icon shown on the map.
  • Measure/save button in the collector shows "Out of CRS bounds" error if the CRS transformation has failed.
  • We slightly updated the third tab design while redeveloping the access to NTRIP profiles – added useful links and the company’s social media.
  • "Fit to project" button on the map now will be disabled if there are no points in the project.
Fixed
  • Fixed an issue that might cause the appearance of a strange gray rover icon on the map, while there is no receiver connected.
  • The collector will no longer show the height of the thread adapter if connected/selected receiver doesn't support it.
  • Fixed a bug that caused errors for some geoid-based coordinate transformations.
  • Fixed base CRS for all projected and compound CRSs based on geographic CRSs unlocked in the version 3.1 Beta. For example, EPSG:27700 (OSGB 1936 / British National Grid) now has ETRS89 as base CRS instead of OSGB 1936.
    Be advised that if you created projects using said coordinate systems, collected data inside them should be considered invalid.
  • Fixed a bug that might have caused geographical coordinates block in point info bottom sheet not to be shown for a custom compound coordinate system.
