Emlid Flow iOS changelog
Changelogs include the release notes for each app version, covering new features, improvements, and bug fixes.
If you don’t have an Emlid account or your data isn’t visible in Emlid Flow 360, do not remove or reinstall the app, as your projects won't be saved. In case of any difficulties, please contact us at [email protected], and we'll be sure to help you out.
15.15 (Nov 4, 2026)​
Added
  • Faces in photo attachments are now automatically blurred before they are saved, to protect people’s privacy.
  • Zooming in the point photo camera now switches between all cameras available on your mobile device.
Fixed
  • Minor fixes and visual improvements.
15.14 (Oct 19, 2026)​
Added
  • Now you can add map layers from your WMS layers library right in the mobile app.
Fixed
15.13 (Oct 14, 2026)​
Fixed
15.12 (Oct 06, 2026)​
Added
  • Now you can name projects, folders, codes, and more the way your team is used to, with longer names and more characters.
Fixed
15.11 (Sep 29, 2026)​
Added
  • Now you can import DWG files, and the CAD file size limit has been raised to 100 MB.
  • Introducing Stake elevation. Enter a design height and tolerance to see live cut and fill and know when you’re on grade — no surface needed.
Fixed
15.9 (Sep 16, 2026)​
Fixed
15.8 (Sep 7, 2026)​
Fixed
15.7 (Sep 2, 2026)​
Fixed
15.5 (Aug 24, 2026)​
Fixed
15.4 (Aug 13, 2026)​
Fixed
15.3 (Aug 7, 2026)​
Fixed
15.2 (August 4, 2026)​
Added
  • Now you can use mobile location to see where you are in a project and get around the job site with your phone’s position.
  • Emlid Flow now supports orthometric heights for external integrations, starting with Reach RX firmware v2.11.
15.1 (July 21, 2026)​
Added
  • Adding Emlid Corrections.
Fixed
15 (July 14, 2026)​
Fixed
14.17 (June 30, 2026)​
Added
  • See color-coded geometries on the map and get instant visual confirmation with colored points and lines right as you collect data.
Fixed
14.16 (June 24, 2026)​
Added
  • Correction Input now shows clearer device icons and warning states, so you can more easily spot NTRIP issues and missing profile setup.
  • The Pro and Business tiers now have the ability to see active rovers on the project map in real time. You can enable this feature in the workspace settings via Emlid Flow 360.
  • When tapping where multiple objects overlap on the map, a picker now appears so you can choose the exact point, line, or surface you need.
  • Now you can control whether collected attributes are exported to CSV by toggling the option in the export settings.
  • Unlocked the ability to collect objects while staking out lines, surfaces, and objects selected from a CAD file.
Fixed
14.15 (June 9, 2026)​
Added
  • Meet the refreshed receiver list and updated app permissions with clearer logic.
  • Exported projects in CSV, KML and Shapefile formats now include information about authorship.
14.14 (May 26, 2026)​
Added
  • Now, you can define custom attributes for point and line codes in Emlid Flow 360, then fill in additional information about objects you collect in a structured way in the mobile app.
  • Emlid Flow now supports orthometric heights for external integrations, starting with Reach RX2 firmware v2.10.
Fixed
14.13 (May 12, 2026)​
Fixed
14.12 (April 28, 2026)​
Added
  • Added new coordinate systems and vertical datums for Germany, Estonia, New Caledonia, Martinique, Réunion, and French Antilles.
Fixed
14.11 (April 16, 2026)​
Added
  • Now, you can link photos to points for as-builts and other documentation.
14.10 (April 8, 2026)​
Added
  • We are pleased to present Danish and Dutch language support!
Fixed
14.9 (March 24, 2026)​
Fixed
14.8 (March 11, 2026)​
Added
  • Added Georgian localization for a smoother experience for Georgian-speaking teams.
Fixed
14.7 (Feb 25, 2026)​
Added
  • Line stakeout modes To line and By segments are now available in AR.
  • Folder management is now available in Emlid Flow 360. Organize your team’s projects and structure complex workflows, then access and work with them seamlessly in the mobile app.
Fixed
14.6 (Feb 6, 2026)​
Added
  • Now you can stake out lines with intervals and offsets in AR.
Fixed
14.5 (Jan 27, 2026)​
Added
  • Added multiple new coordinate systems and vertical datums for Albania, Canada, Germany, Greenland, Indonesia, Saudi Arabia, South Korea, Sweden, and others.
Changed
  • ‘Romania MN75 height’ updated to ‘RomHybQGeoid2025.05’.
Removed
  • Removed deprecated legacy coordinate systems with known issues.
Fixed
14.4 (January 13, 2026)​
Fixed
14.2 (Dec 9, 2025)​
Fixed
14 (Dec 3, 2025)​
Added
  • The Survey plan has been renamed to Pro. All existing subscribers keep full access to paid features.
  • Added support for new team collaboration features.
Fixed
13.18 (Nov 26, 2025)​
Added
  • Explore survey features more easily with Virtual Reach. Just enable the receiver in Profile tab > Settings > App settings and connect to it in the Receivers tab.
  • Other improvements for the Profile tab: you can find all app-related settings, such as app version, receiver analytics, and troubleshooting reports, in a separate section, Settings > App settings.
  • Now you can edit your profile name right in the app.
13.16 (Nov 10, 2025)​
Fixed
13.15 (Oct 29, 2025)​
Added
  • Save visibility for CAD, DTM, and WMS layer opacity as a map preset and it will be automatically synced across all your devices. Tweak settings anytime and tap Reset to return to your saved view.
  • We simplified project setup: instead of settings scattered across screens, there’s now a single, consistent workspace configuration. Set it once and new projects (and related screens) will use your defaults. You can still override any option when creating a new project. As part of this change, angular units will be reset once. Reapply your preferred units in Settings → Workspace settings.
Fixed
13.14 (Oct 1, 2025)​
Added
  • To improve the experience of navigating the map out in the field, we are making the satellite map style available on the free tier of Emlid Flow!
  • We refreshed the app’s look and feel to align with Emlid’s new brand system.
Fixed
13.11 (Sep 9, 2025)​
Fixed
13.10 (August 26, 2025)​
Added
  • Exported CSV files now include additional information: receiver’s model and serial number for collected points and descriptions for survey codes.
Fixed
13.9 (August 12, 2025)​
Fixed
13.8 (July 25, 2025)​
Added
  • The Inverse tool and the line info view now display the angle value for three-point lines.
  • We are pleased to present Swedish language support!
Removed
  • The Turkish localization is no longer available in the app.
Fixed
13.7 (July 15, 2025)​
Fixed
13.6 (July 1, 2025)​
Fixed
13.5 (June 17, 2025)​
Added
  • We are introducing the Intersection functionality! The new tool lets you calculate a point at the intersection of distances or directions from two known points.
  • Survey plan users can now stake out lines at specified intervals, with the option to apply horizontal and vertical offsets. Just select a line, start stakeout, tap the mode name, and switch to ‘By intervals & offsets’.
Fixed
13.4 (June 09, 2025)​
Fixed
13.3 (June 03, 2025)​
Fixed
13.2 (May 17, 2025)​
Fixed
13.1 (May 17, 2025)​
Added
  • Update Emlid Flow to version 13 to keep your projects synced with the cloud and accessible via your Emlid Account. In a few months, new data collected with older app versions will no longer be accessible in Emlid Flow 360 and other devices.
13 (May 6, 2025)​
Added
12.2 (Apr 23, 2025)​
Added
  • The Traverse tool now supports calculating 2D distance and direction by selecting two existing points instead of entering an exact value.
  • Added new coordinate systems for Jamaica, Costa Rica, Turkey, and the Netherlands, as well as the ‘JPGEO2024’ geoid for Japan. Fixed
12.1 (Apr 2, 2025)​
Added
  • You can now configure format settings before exporting a project.
  • Line stakeout now lets you track the distance along the entire line without having to manually switch between segments.
  • Now, when you work with CAD drawings, you can select line vertices right from the map. Additionally, points from the drawing are visible and can also be selected.
Fixed Minor fixes and visual improvements.
12 (Mar 19, 2025)​
Added
  • Emlid Flow now allows you to upload your CAD designs for set-out or as-built. It keeps the drawings the way they were created: retaining the geometry view, colors, and annotations. You can stake out objects from the plan or simply use it as a background.
  • Added support for “Transverse Mercator (South Oriented)” projection type, so now “Hartebeesthoek94" CS works correctly.
  • Introduced additional CSs for South Africa and Namibia: “Cape” and “Schwarzeck”.
Fixed
11.12 (Feb 25, 2025)​
Fixed
11.11 (Feb 13, 2025)​
Added
  • You can now export and import data in PNEZD CSV format.
  • Reach receivers can now be updated directly through the Emlid Flow app. This includes Reach RX units with firmware 1.6 and newer.
Fixed
11.10 (Jan 31, 2025)​
Added
  • Updated and additional coordinate systems were introduced for Singapore, Norway, and Bonaire Island. This update also includes an option to use the beta version of the latest ‘GSIGEO2024’ geoid in Japan.
Fixed
11.9 (Jan 17, 2025)​
Fixed
11.8 (Dec 18, 2024)​
Added
  • Meet the updated Wi-Fi settings screen! Connecting to networks is now easier and more convenient with the improved user interface.
11.7 (Nov 23, 2024)​
Added
  • With this update, you can change the linear unit of your projects even after creation. Additionally, the status overview screen now includes a switch for the linear unit, enabling you to view data in feet.
  • We added support for US coordinate systems using feet and US survey feet units, enhanced the GCVerticalAdjustment with a UOM property, and implemented 13 new vertical datums for New Zealand's regional height systems. Additionally, we introduced datum transformation between GDA2020 and AGD84 for Australian coordinate systems, improving compatibility with AGD84-based systems.
  • With this update, the app is now significantly better at handling larger projects. The object list and map are more responsive, even when managing extensive amounts of data.
  • Added the ability to edit a point’s coordinates by duplicating it, making it easy to correct errors from faulty data imports or mistakes made during point creation.
11.6 (Nov 07, 2024)​
Fixed
11.5 (Oct 26, 2024)​
Fixed
11.4 (Oct 10, 2024)​
Fixed
11.3 (Sep 20, 2024)​
Added
  • Additional coordinate systems were introduced for Australia, Puerto Rico, the USA, the Philippines, Latvia, the Bailiwick of Guernsey, and the Bailiwick of Jersey.
  • Meet the offset configuration for DTM! To set a temporary vertical offset, enter the desired value (up or down) in the survey settings. This feature allows you to work with one DTM file at different stages of a project.
  • Enabled the ability to collect points during surface stakeout. Please note that currently, measured points will not include delta information and will not be added to the stakeout report.
  • The line and point stakeout over DTM has been improved. You can now simultaneously view cut/fill values from your current position to the DTM and to the elevation of a point or line.
  • The app now supports polygon geometries! You can collect polygons on the go or create them from previously collected points and lines, streamlining boundary definition for faster and more efficient results.
Fixed
  • Minor fixes and improvements.
11.2 (Aug 23, 2024)​
Added
  • Now you can key in pre-calculated localization parameters while creating a custom coordinate system.
Fixed
  • Various fixes and improvements.
11.1 (Aug 05, 2024)​
Added
  • The app now provides notifications for critical Reach Firmware updates.
Fixed
11 (Jul 31, 2024)​
Added
  • We are excited to introduce surface stakeout in the Emlid Flow app! You can now upload DTM files in LandXML format and get cut and fill values during surface stakeout. Additionally, cut and fill values are calculated from surface elevation during points and lines stakeout.
Fixed
10.9 (Jul 02, 2024)​
Added
  • This update includes enhancements to the data safety mechanism. It is highly recommended to install this update.
  • You can now select line codes when creating or editing a single point.
  • You can now receive product-related announcements via the in-app newsletter. To check out the latest news, go to Profile > What's new.
Fixed
10.8 (Jun 18, 2024)​
Added
  • We are pleased to present Japanese language support!
Fixed
10.7 (Jun 04, 2024)​
Fixed
10.6 (May 24, 2024)​
Added
  • Added the ability to select the preferred angle display format: DD or DMS.
  • We're excited to announce that the Survey plan now includes Auto collection mode. This feature allows you to automatically collect points and lines at specified time or distance intervals. To set up this mode, go to the Survey settings under the gear icon in the Collector tool.
Changed
  • With this update, you can expect improved connection stability when interacting with a receiver via Wi-Fi or Bluetooth.
  • The inverse tool now visualizes enclosed area.
  • More actions are now available on the project's Tools screen.
Fixed
10.5 (May 07, 2024)​
Fixed
10.4 (Apr 23, 2024)​
Added
  • We are pleased to present Czech language support!
  • Information about collected points is extended to include GDOP, NTRIP mountpoint info, and the number of satellites for each constellation.
Fixed
10.3 (Apr 09, 2024)​
Added
  • We updated the Collector tool with the “Precision limit” setting! Now you have more control over the quality of the data you collect. This new feature is available in both Free and Survey plans.
Fixed
10.2 (Apr 02, 2024)​
Added
  • We are introducing the Inverse and Traverse functionality! Now, you can use the Inverse tool to view information about the selected points (area, slope distance, 2D distance, etc.). The Traverse tool lets you calculate a new point based on an existing point and the distance, azimuth, and elevation difference you enter.
Fixed
10.1 (Mar 20, 2024)​
Added
  • Added the ability to check for Reach RX firmware updates and a more reliable checking mechanism for other receivers.
Fixed
10 (Mar 04, 2024)​
Added
  • We are introducing the Stakeout report feature. Now you can save points directly from stakeout mode and export the coordinate deltas as a CSV report.
Fixed​
9.12 (Feb 13, 2024)​
Fixed
9.11 (Jan 30, 2024)​
Added
  • The Line Info screen now provides more information about each segment of a line.
Fixed
9.10 (Jan 15, 2024)​
Added
  • It’s possible to save calibrated coordinate systems, and then use them in other projects in the same work site. Name the new system and you’re done!
9.9 (Dec 20, 2023)​
Added
  • Starting with firmware 31.6 you can use Bluetooth to connect to your Reach. This feature is in the beta stage.
  • The Line Info screen now provides more information, including area, perimeter, direction, grade, and more. The information depends on the number of points in the line.
Fixed
9.8 (Dec 12, 2023)​
Added
  • Sending corrections to the Reach RX will continue even when the app is background or the screen is locked.
Fixed
9.7 (Nov 28, 2023)​
  • The stakeout tool now displays the azimuth value. The azimuth value is a measure of the direction from a rover to a target in point stakeout, and to an intersection point in ‘To line’ mode.
  • Now your preferred stakeout mode is automatically remembered, providing a smoother experience.
Fixed
9.6 (Nov 15, 2023)​
Added
  • With this update, projects with a projection will use grid distances in the calculations. Projects in the Global coordinate system will use ground distances.
  • We updated the formatting of distances in the Stakeout tool and line info screen. The new format provides centimeter-level accuracy even for long distances.
Fixed
9.5 (Oct 31, 2023)​
Added
  • Added new coordinate systems for Ireland, Germany, and Hong Kong.
  • Updated the geoid used for ‘DVR90 height’ to a newer version.
  • Survey plan subscribers can now export CSV files with a custom format. The file configuration is taken from Emlid Flow 360.
Fixed
9.4 (Oct 18, 2023)​
Added
  • You can now get instant logging feedback right from the status bar and more detailed information from the status overview. In addition, the process of starting and stopping logging is more accessible through the integration of native logging controls.
Fixed
9.3 (Oct 5, 2023)​
Fixed
9.2​
Added
  • We updated the Profile section of the app. You can now find the link for documentation for every Emlid receiver and software product. The offline PDF docs are also available for download at the bottom of the documentation page.
Fixed
9.1​
Added
  • We are introducing a new Stakeout mode! Now the map automatically rotates so you can quickly find your position relative to a point or line. The old Stakeout mode is available by tapping the Follow button on the map.
  • Added more options to manage lines: change code, add or remove points, reorder points within a line. Also, you can delete lines while keeping the points.
  • The Collector tool now allows to select on which side of the line you want to collect a new point.
  • Added a bunch of WGS84-based projections for India.
  • Added a new vertical datum was introduced for high-precision measurements in Bucharest, Romania—Bucharest-Ilfov MN75 height.
  • The UTM zones 34N and 35N of the ETRS89 datum are now available for Romania.
  • The Romania MN75 height was renamed to MN75 height and updated and now it uses the latest version of the geoid: EGG97_QGRJ_2023.tif.
Fixed
9​
Added
  • We are pleased to introduce a major update of the Survey plan—Localization. With this new feature you can calibrate your work site to fit existing control points for better precision.
Fixed
8.11​
Added
  • The ‘FIX only’ option is now available for the Stakeout tool. When turned on, the setting will also show a notification in the status bar, highlighting insufficient conditions.
Fixed
8.10​
Added
  • Survey plan users can now create new lines from existing points. To create new geometries, go to the list of Objects, tap the ‘plus’ icon at the top, and then select points on the map or from the list.
  • We added new ‘ETRS89’ to ‘MGI’ transformation that uses the updated 2021 version of the ‘AT_GIS_GRID’ grid. ‘ILUM2 height’ for Israel was also added.
  • Unlocked the ability for Survey plan users to edit WMS layers in the Collector and Stakeout modes.
  • You can now rotate the project map for better orientation in the field.
Fixed
8.9​
Added
  • You can now search the lists of projects and NTRIP profiles.
Fixed
8.8​
Added
  • We added support for South African CRSs based on the Hartebeesthoek94 datum. The South African vertical datum SAGEOID2010 was also added.
Fixed
8.7​
Added
  • You can now import points using CSV (PENZD) format.
  • We added new vertical datums for Thailand (Kolak-1915 height) and Italy (Genoa 1942(South Tirol) height). Support for Israeli CRSs (Israeli Grid 05/12, Israeli Grid 05) has also been added.
Fixed
8.6​
Added
  • You can now select and view point and line information directly from the collect and stakeout modes.
Fixed
8.5​
Added
  • Survey plan users can now change points' codes. That includes older data created before coding was introduced to Emlid Flow. Note that this update also fixes the ordering of objects when exporting or importing data.
  • Meet the updated object list in the project view! Check out the improved search logic and redesigned display of lines' contents.
8.4​
Fixed
  • Exported DXF files now have a new layer with survey codes.
8.3​
Added
  • The iPad version of the app now shows the project list as a grid, using screen space more efficiently.
  • Survey plan users can now change a project's code library and edit code of a point. That includes older data, created before coding was introduced to Emlid Flow.
  • Survey plan subscribers can now add WMS layers to the map for better context and navigation.
8.2​
Changed
  • Field names of exported shapefiles were changed slightly to achieve better compatibility with third-party software.
Fixed
8.1​
Fixed
8​
Added
  • ReachView 3 is now Emlid Flow! The new app includes professional survey features. Collect and stake out points and lines, perform stakeout with offset and chainage. Use our code library or upload your own to collect data faster. Use a satellite map view for more context.
7.15​
Fixed
  • Various fixes and visual improvements.
7.14​
Added
  • You can now control the quality of satellites’ signals by checking the SNR values on the Status screen.
  • Non-web-based interface that allows renaming the connected receiver.
Fixed
7.13​
Fixed
7.12​
Fixed
7.11​
Added
  • The NTRIP over Bluetooth option now works correctly with NTRIP services that use TLS protocol.
Fixed
7.10​
Added
  • Redesigned receiver Settings view. The most frequently used settings are now on the Receivers screen when Reach is connected. The Settings screen is rearranged and unnecessary nesting of views is eliminated.
7.9​
Added
  • ReachView 3 shows the total distance value next to the rover icon on the map during the stakeout process.
  • It is possible to scroll the buttons above the Collector tool to the right to check the real-time coordinates of the receiver during the data collection process.
Fixed
7.8​
Fixed
7.7​
Added
  • A list of verified coordinate systems which are searchable by country, name, and EPSG codes. Corresponding systems from the EPSG registry are marked as legacy, but still available.
  • Redesigned Stakeout and Collector tools. The map in the new Stakeout is always oriented towards North. The ground distance is split by North-South and East-West axes. The new Collector is more compact so you can see a larger part of the map, and the new color scheme making the interface more visible in bright sunlight. The tool has the new Measure button to ease the collection process.
Fixed
7.6​
Added
  • Slovak language localization.
  • It is now possible to request account deletion.
Fixed
7.5​
Added
  • There is a new visual improvement of the stakeout tool: when you get closer than 40&nbspcm (1.312&nbspft) to a point, you can match the point and the rover more easily.
Fixed
7.4​
Added
  • It is now possible to enter a base’s position or points’ coordinates in the DMS format.
  • Added the datum transformations from ‘ETRS89’ to ‘S-JTSK (Ferro)’ and ‘S-JTSK [JTSK03]’ for Slovakia, and from ‘ETRS89’ to ‘Albanian 1989’ for Albania.
  • There is a new ‘NTF / Lambert Corse’ coordinate system support.
Fixed
7.3​
Added
  • You can now set project points as base position. That enables you to add a survey marker position to a project as a point, then use this point to set up your base.
Fixed
7.2​
Added
  • When connected to a receiver, you can now change its Bluetooth settings and manage its paired devices.
Fixed
7.1​
Added
  • We added new vertical datums for Columbia (Colombia GeoCol2004 height) and Azores Islands (Portugal GEODAZ2014 height).
Fixed
7​
Added
  • We are happy to introduce the next major update for the app—Cloud sync! Log into your Emlid Account and store your projects, coordinate systems, and NTRIP profiles in cloud storage. No longer worry about losing data if the hardware fails; work with multiple mobile devices with ease! The app will sync your work every time it has access to the Internet without requiring a persistent connection.
  • Meet the updated General settings screen! Now you can check Reach Firmware updates, get system reports, and restore the receiver’s initial settings using the new UI.
  • The app now supports exporting Shapefiles with global coordinates.
Fixed
6.17​
Fixed
6.16​
Changed
  • The app now shows more verbose warning messages if there is an issue with NTRIP credentials or the selected mountpoint.
Fixed
6.15​
Added
  • Exported CSV files now have additional columns containing geographic coordinates of the base.
Fixed
6.14​
Added
  • ReachView 3 now supports DXF export with the point name and height as text objects.
  • The collector tool now makes a sound upon successful point collection.
  • Added a new option for the Correction output—‘Local NTRIP’.
Fixed
6.13​
Added
  • We added the ability to delete custom coordinate systems.
  • Exported CSV files now have an additional column containing the name of the coordinate system.
  • We added the ability to edit the name and description of existing survey projects.
  • Added the new transformation from RGF93 to NTF used for all CRSs based on NTF datum. These systems now require grid downloading.
Fixed
6.12​
Added
  • Added the datum transformation from ETRS89 to Belge 1972, used in Belgium.
  • There are new vertical datums: ‘Brazil hgeoHNOR2020 height’, ‘South Africa SAGEOID2010 height’, and ‘Belgium HBG18 height’.
  • Added two vertical datums for France: ‘NGF-IGN69(RAF18B) height’ and ‘NGF-IGN69(RAF20) heigh’.
Changed
  • We increased the maximum collection time to 60 minutes.
  • Coordinate systems without a projection are discontinued. This kind of systems has been removed from the list, and you can no longer create custom coordinate systems without specifying a projection. If you want to work in degrees, you may use the new Global CS option.
  • Position accuracy is now shown at all times, not just when averaging.
Fixed
6.11​
Added
  • We are happy to introduce new languages support! Translations in French, German, Italian, Norwegian, Polish, Portuguese, Russian, Spanish, and Turkish are now available.
  • Updated the UI for Position streaming settings.
Fixed
6.10​
Fixed
6.9​
Added
  • ReachView 3 now supports import and export of projects in Shapefile and DXF formats.
Fixed
6.8​
Added
  • Meet the new base shift feature, which allows applying a real-time shift to rover and base coordinates. To do this, open the corresponding wizard from the project info bottom sheet and select measured and known points.
Changed
  • Now, devices with a Firmware version lower than 26 need to be updated to work with ReachView 3.
Fixed
6.7​
Added
  • We present you the ability to add points to a project by manually entering coordinates! While in the project, head to the points list, where you can now find a new control to add a point. Fixed
6.6​
Added
  • Meet the updated Base mode settings screen! Configure automatic base position averaging or enter exact geographic coordinates manually using the new UI.
  • Add new vertical CRSs for South Korea: ‘KNGEOID13 height’, ‘KNGEOID14 height’, and ‘KNGEOID18 height’.
  • Added required transformations to ensure correct work of the surveying features on Hawaii.
Fixed
  • Fix the 7-parameter transformation for the GGRS87 system (Greece) to work as expected.
6.5​
Fixed
6.4​
Fixed
  • Fixed an issue that could change points’ coordinates upon import if the project uses a custom CRS with Molodensky-Badekas transformation. If you encountered such behavior, we recommend creating a new project.
6.3​
Added
  • Now, you can restart and shut down your Reach from the app! To do this, tap on the connected device on the scanner or device settings screen and select a corresponding menu item.
  • Added new vertical datum, ‘Greece GREEKGEOID2010 height’, used in Greece.
  • There are new horizontal CRSs for Greece: ‘HTRS07’, ‘HTRS07 / TM07’, ‘GGRS87’, and ‘GGRS87 / HEPOS’.
  • Added a new ‘Baltic 1977 height’ vertical datum for Georgia.
Fixed
6.2​
Fixed
6.1​
Fixed
6​
Added
  • We are proud to present the next major update of the app. Starting with this version, it is now possible to create custom coordinate systems by entering all needed parameters. To test the new functionality, head to the list of coordinate systems and hit the ‘plus’ button.
  • We now support a new vertical datum, ‘Italy ITG2009 height’.
Changed
  • All projects in Italy that use CRSs based on ED50 datum will utilize the transformation from ETRS89 to ED50 by ‘italy_ed50.tif’ horizontal grid.
  • All projects in Italy that use CRSs based on Monte Mario datum will utilize the transformation from ETRS89 to Monte Mario by ‘roma40.tif’ horizontal grid.
5.9​
Added
  • Starting with Reach Firmware version 26, the app will save the highest PDOP value received during point collection. These values will be available in exported CSV files.
Fixed
5.8​
Added
  • The Swiss vertical CRS ‘LHN95 height’ is available once again! Be advised that projects created before the system’s temporary removal will ask you to re-download the geoid file.
  • There is a new vertical datum ‘LN02 height’ for Switzerland.
  • Added an ability to check base coordinates in the point info drawer.
Changed
  • Update metadata for a bunch of geoid files. It will affect projects based on ‘SRVN16 height’, ’Latvia 2000 height‘, ‘NN2000 height’, and ‘N60 height’ vertical datums. Existing projects that use these vertical datums will ask you to re-download updated files upon opening.
Fixed
5.7​
Added
  • Now, you can copy point coordinates and CRS info from the project's bottom sheets with a long tap on them.
Fixed
5.6​
Added
  • The vertical CRS ‘DHHN2016 height’ used in Germany is back! Please note that projects created before the system's temporary removal will ask you to re-download the geoid file.
  • There are two new vertical datums for Hungary: ‘Hungary VITEL2014’ and ‘Hungary EHT2014 height’.
  • Added the transformation from ETRS89 to HD72 by ‘etrs2eov’ horizontal grid, used in Hungary. Now, all CRSs based on HD72 datum will utilize this transformation.
Changed
  • Updated distance formatting in the stakeout tool to make precise measurements over long distances easier.
Fixed
5.5​
Added
  • We made the map reading easier by adding a scale bar to it.
  • The averaging timestamps in exported CSV now contain a time zone offset. This will help to preserve information when importing a project in a different time zone.
  • There are two new vertical datums for Croatia ('HVRS71 height') and France ('NGF-IGN69(RAF09) height').
  • The EPSG list was updated in accordance with the EPSG v10.003.
Fixed
5.4​
Added
  • The correction input settings screen and the status overview drawer will now show if your device is receiving corrections.
  • Correction output settings will now notify you if LoRa requires a higher air data rate. This feature covers the case when you enable LoRa, but the set air date rate doesn't suffice for configured RTCM3 messages. In such a case, the app will prompt you with a dialog describing the situation.
  • Exported CSV files now also contain geographic coordinates of points.
Fixed
5.3​
Fixed
5.2​
Added
  • Zoom buttons on the map are now muted when reaching maximum values.
  • We added new vertical CRSs to support the legacy 'GEOID12B' geoid. It covers the CONUS area and Alaska 'NAVD88(GEOID12B) height', Virgin Island 'VIVD09(GEOID12B) height' and Puerto Rico 'PRVD02(GEOID12B) height'.
Changed
  • Slightly updated fonts in the status overview to make values more readable.
Fixed
  • The status overview now shows the PDOP value with one decimal place.
5.1​
Fixed
5​
Added
  • Added a view with device status data! Coordinates, solution status, DOP, info about corrections, you name it. You can access the device status overview page anywhere in the app by tapping on the status bar.
  • Survey project wizard became smarter, and now it remembers the last used CRS setup.
Fixed
5 Beta​
Added
  • We added new vertical CRSs for Argentina and Brazil.
  • Notification about new Reach firmware update has been added to the device settings screen, so you do not miss out on new functionality.
Changed
  • Now, devices with a firmware version lower than 2.24.0 need to be updated to work with ReachView 3.
  • Correction output settings are fully available! We unlocked the NTRIP option and added the possibility to edit Serial configuration too.
  • The device scanner now shows more verbose errors and allows you to do the first setup or update receivers directly from the app.
  • Updated the grid required by 'Romania MN75 height' CRS as the previous version caused incorrect height transformations. Existing projects won't be affected, but you'll need to download the new file. Be advised that exported CSVs are prone to have erroneous height values.
Fixed
Removed
  • Removed CRSs 'DHHN2016 heigh' and 'LHN95 height' due to license issues. Existing projects will continue to work correctly, but you will be unable to use said systems for the new ones.
4.9 Beta​
Added
  • Added quick links to configure your receiver via the web interface. Now you can configure all settings without leaving the app.
  • You can now access the web-based logging page from the Receives tab! We tweaked a few things, and downloaded logs now can be shared using the native iOS interface.
  • We added new vertical CRSs for Slovenia, Continental Portugal, Mexico, Lithuania, and Romania.
Changed
  • Now, it is possible to edit TCP and LoRa configurations in correction output settings.
4.8 Beta​
Added
  • A fancy splash screen will now greet you upon opening the app!
  • The correction output settings are here! For now, you can only switch between IO channels — configuration wizards are coming in future updates.
  • We added a new vertical CRS 'Latvia 2000 height' along with 'lv_14.tif' geoid, which covers all Latvia areas.
Changes
  • A small yet useful update for the point info: we moved the point editing button to the top. You'll no longer need to drag the bottom sheet up and down — all essential controls will be near at hand.
Fixed
4.7 Beta​
Added
  • The Sound settings for your Reach RS2 devices are unlocked!
  • We added support for a bunch of new vertical coordinate systems! This update includes CRSs for Austria, New Caledonia, Balearic Islands, Canary Islands, Ceuta, Alicante, and Slovakia.
Changed
  • We changed the default base CRS for some coordinate systems used in New Caledonia, Slovakia, and Romania.
  • The 'Can't find Reach?' hint on iOS 14 was updated to include information about local network access permission.
Fixed
  • Prevented the system from deleting downloaded geoids/grids while trying to automatically free-up device storage.
Removed
  • The EPSG list was updated in accordance with the EPSG v9.8.12 and ESRI v10.8.1.
4.6 Beta​
Added
  • Now it is possible to edit TCP and LoRa configurations in correction input settings.
  • Added a delete point button to the point info bottom sheet so you can delete points without opening point editor.
Changed
  • Now, after you edit Serial configuration, it will be automatically selected as a correction input setting.
Fixed
  • Fixed improper behavior of the settings screens when the connection with a receiver is lost.
4.5 Beta​
Added
  • Now, you can see all points of a project as a list! Access the list by tapping on a button on the bottom left corner of the map or 'Points' in the project info view. Overview your work, get primary info on project data, and select points with ease.
  • Serial configuration is now editable in correction input settings.
4.4 Beta​
Added
  • Now, the project map shows the position of the base if it's available.
  • Project import and export were upgraded to support base position and baseline. These values can be imported (and exported) using the following headers: Base easting, Base northing, Base elevation, and Baseline.
  • We've added some protection against accidental cancels during point connection. If averaging time is more than 10 seconds, canceling the collection must be confirmed by additionally tapping a new stop button.
  • Now the point collection tool shows a countdown. You can switch countdown mode between how much time has passed and how much time has left by tapping on it. The switch state is saved throughout the app.
Changed
  • Now when you tap on a deleted project, you will be prompted to delete the project permanently or restore it.
Fixed
  • We fixed an issue with project import that was working incorrectly with imperial units. Previously, points' RMSE, antenna height, and the baseline were not imported correctly if your project CRS used feet as a measuring unit (values were multiplied by 3.28). This issue did not affect the points' coordinates. Be advised that earlier imported points might have unreliable metadata. We are sorry for the inconvenience.
4.3 Beta​
Added
  • Added 'FIX only' setting that allows point collection only with FIX solution.
  • When you create an NTRIP profile, you will automatically receive a list of mount points provided by your caster.
  • The third tab was renamed to 'Profile' and now contains your NTRIP profiles. You can modify existing profiles and create new ones there. If you create or edit an NTRIP profile, and any Reach is connected at that moment, the app will ask you if you want to change settings on that Reach.
  • We've added new experimental vertical CRS "DHHN2016 height" along with "CGC2016.tif" geoid, which covers almost all Germany areas. Exact coordinates of coverage area: from 47.225° to 50.6° in latitude, from 7.426° to 13.9° in longitude.
Fixed
4.2 Beta​
Fixed
4.1 Beta​
Added
  • Added new coordinate systems for Ghana and Sierra Leone (ones which use Gold Coast Foot unit of measure).
  • Added more detailed hints when entering values in the NTRIP profile wizard.
  • Interactions with projects now will be restricted in case if required grid/geoid files are corrupted or missing. In such a case, the app will ask you to download missing files.
  • Now all geoid and grids use .tif format instead of .gtx and .gsb. Previously created projects may ask to re-download grid/geoid files. Sorry for the inconvenience.
  • Update the EPSG systems list in accordance with the EPSG v9.8.9.
  • Add new vertical CRSs: EPSG:5709(NAP height), EPSG:3900(N2000 height), EPSG:5717(N60 height).
  • Add new experimental vertical CRSs: EPSG:5621(EVRF2007 height) (along with 'gugik-geoid2011-PL-EVRF2007-NH' geoid, used in Poland), EPSG:5729(LHN95 height) (along with 'CHGEO04A' geoid, used in Switzerland).
  • Change default base CRS for all projected and compound CRSs based on geographic 'CH1903+' and 'DHDN' to 'ETRS89'.
Changed
  • We now use a different way to calculate accuracy estimates. The RMS numbers you see will be slightly higher, but they will also be more realistic.
  • The collector tool now reuses the description of the last collected point for a new one. You still will be able to clear it via the Edit dialog.
  • Project import was upgraded to support point metadata, like solution status and antenna height. Here's a full list of supported headers: Easting RMS, Northing RMS, Elevation RMS, Lateral RMS, Antenna Height, Solution Status, Averaging Start, Averaging End, Samples.
  • Now devices with a firmware version lower than DEV 2.23.8 need to be updated to work with ReachView 3.
Fixed
  • Sometimes the device scanner was failing to detect receivers' firmware version, which resulted in non-verbose error messages when trying to connect to a Reach. This issue has been fixed.
  • Fixed the correction input settings screen, which was failing to display current LoRa parameters.
  • Now, when the 'follow rover' mode is active, the rover will always be centered on the visible area of the map.
  • 'Fit to project' functionality was fixed, now your points will be centered on the map, without disappearing under point info screen.
Removed
  • Due to technical issues, we had to remove multiple CRSs based on a non-EPSG geographic coordinate system (ESRI:53075, ESRI:53077, ESRI:53078, ESRI:53079, ESRI:53080, ESRI:102038, ESRI:102061, ESRI:102096, ESRI:102163, ESRI:102237, ESRI:102498).
4 Beta​
Added
  • We introduce support for NTRIP profiles! Now you can easily configure correction input via NTRIP using in-app presets of settings.
  • Now you can select any IO channel for correction input.
  • The status bar now shows Reach RS2 modem status.
Changed
  • If you cannot find any Reach on the receiver list, the text placeholder will now remind you to connect to your Reach via Wi-Fi.
Fixed
  • Visual fixes.
  • The project creation wizard will no longer reset selected vertical CRS for no reason.
