Working with NTRIP service
This guide explains how to configure your Reach RX2 to receive corrections from an NTRIP service over Bluetooth.
With the help of Emlid Flow, you can easily configure your Reach RX2 to receive corrections from an NTRIP service over Bluetooth. The app uses the Internet connection on your phone or tablet to access network corrections and send them to Reach RX2 over Bluetooth. Reach typically uses about 16 MB of mobile data per device over 8 hours when connected to NTRIP. Reach supports NTRIP services that provide corrections in the RTCM3 format (MSM4 and later), including most local and public NTRIP services.
In order to access NTRIP services, you need to register and get a subscription. The cost and coverage area depends on your NTRIP service provider.
To configure your Reach RX2 as a network rover, follow the steps below.
Apply NTRIP profile
Emlid Flow allows you to add an NTRIP profile and apply it for correction input at once. To configure correction input on your Reach RX2, follow the steps below:
Connect to your receiver using Emlid Flow.
tipLearn more about connection in the Connecting to Reach RX2 guide.
Tap Correction input and configure your Reach RX2 to receive network corrections over Bluetooth.
tipYou can also choose Emlid Corrections, Emlid's built-in VRS RTK corrections service for compatible Reach receivers. It includes one year of free service for both existing and newly purchased compatible devices. For coverage area and setup instructions, see the Emlid Corrections documentation.
When using NTRIP, Dynamic status messages provide setup guidance and display the current correction input status, so you can quickly determine whether any action is required.
Tap Add profile and enter the credentials and connection details provided by your NTRIP service provider:
tipTo find out which mount point suits you better, check the website of your NTRIP provider. Make sure that the baseline doesn't exceed 60 km (37 mi).
tipOn some Android devices, default keyboards do not provide a minus sign. To get access to it, we recommend downloading Gboard, a virtual keyboard app, from the Google Play Store.
noteIf your NTRIP provider requires information about the receiver's position, such as VRS service, enable Send receiver's position to the provider.
Tap Save. If you are outdoors and everything is configured correctly, you will start receiving corrections in a few seconds.
noteTo start receiving corrections, make sure that your receiver has satellite visibility.
You can add a required number of NTRIP profiles and choose between them right on the Correction input screen later.
Provide Reach RX2 with clear sky view
Before surveying, make sure your Reach has a clear sky view of at least 30° above the horizon. There should be no obstacles that could block the view like buildings, trees, cars, humans, laptops, etc.
Learn more about Reach RX2 placement in the Placement guide.
Viewing results
When you have completed your RTK setup, you can watch the current solution status in the top right corner of the Emlid Flow app or watch the Status LED on your Reach RX2:
SINGLE means that Reach has found a solution relying only on the satellite signals. In this case, the precision is usually at the meter level.
FLOAT means that Reach receives corrections from the base station but cannot resolve ambiguities needed to calculate its position with centimeter-level accuracy. In this case, the positioning accuracy can vary from a few centimeters to about 1 meter.
FIX means that Reach using the base corrections calculated a solution with a centimeter precision.
Reach RX2 gets a fixed solution within a short period of time. In good environments, it will take a few seconds. In tough conditions, it may take a little longer. Once the rover gets FIX, you are all set for surveying.
You can also find the current solution status as well as your real-time position on the Status screen.
Your Reach RX2 will continue to receive NTRIP corrections even when the Emlid Flow app is in the background or the screen is locked.
Video guide
The Emlid Flow app is regularly updated, so the interface in the video may look a bit different from the current version.
Checklist
For a reliable NTRIP connection, make sure the following conditions are met:
- The receiver is in an open area with a clear view of the sky.
- You have internet access.
- Each NTRIP account is used with only one rover at a time.
- The username, password, and mount point match the credentials provided by your NTRIP service.
- The selected mount point provides corrections in the RTCM3 format. Other formats, such as CMR, are not supported.
- If you're using Emlid Caster, a local base is connected to the caster and transmitting corrections.
- The baseline doesn’t exceed 60 km.
