RTK setups overview
- a stationary base station
- a moving rover
RTK setups
| Workflow | How it works | Internet required | Local base required | Best for | Third-party compatibility |
| LoRa | Base and rover communicate over Emlid's LoRa radio | No | Yes | Open areas without cellular coverage | Emlid receivers only |
| UHF | Base and rover communicate over UHF radio using Trimtalk 450S protocol | No | Yes | Dense vegetation or urban environments and mixed-fleet setups | UHF-compatible receivers supporting Trimtalk 450S protocol |
| Emlid Corrections | Rover receives RTK corrections from Emlid’s service over the internet with an activated receiver license | Yes | No | Working without a local base station in areas with reliable cellular coverage | Not relevant |
| Emlid Caster | Base and rover communicate over the free Emlid Caster service via the internet | Yes | Yes | Multi-rover sites with need for control over base | Any NTRIP-compatible receiver |
| RTK network (NTRIP) | Rover connects to a third-party corrections network over the internet using NTRIP credentials provided by the service provider | Yes | No | Working without a local base station in urban and semi-urban areas with good cellular coverage | Not relevant |
RTK setup basics
Satellite visibility
For RTK, both the base and rover need a clear view of the sky. Each receiver tracks satellites across multiple constellations. The more satellites visible simultaneously, the stronger and more stable the solution. Obstructions above 15 degrees of elevation, such as buildings, trees, and heavy canopy, block signals and reduce the usable satellite count.
Communication link requirements
Line of sight
Baseline length
Electromagnetic interference
Coordinate system
- the base coordinates are defined in the correct coordinate system,
- the rover project uses the correct coordinate system,
- and any localization or transformation parameters match the project requirements.
