Canadian Spatial Reference System Precise Point Positioning (CSRS-PPP)
This guide explains how to get the precise coordinates of a standalone receiver using the Canadian NRCan CSRS-PPP service.
The Canadian Spatial Reference System (CSRS) PPP service is provided by Natural Resources Canada's Canadian Geodetic Survey. It uses single or dual-frequency GPS and GLONASS data for solution computation and supports both Static and Kinematic modes.
Static computation is accomplished with a receiver sitting on one point. As the result of Static mode, you will get the absolutely determined position of this point.
Kinematic mode allows surveying with a moving receiver and provides a path as the solution.
Depending on the accuracy level and time that is required to get the solution, the NRCan CSRS-PPP service can calculate the data in the following modes:
| Orbit type | When the orbit is ready for use | Accuracy |
| ULTRA-RAPID | about 60 minutes after the end of each hour | ~15 cm |
| RAPID | about 12 hours after the end of each day | ~5 cm |
| FINAL | 12 days after the end of each week | ∼2 cm |
You can learn more about the NRCan CSRS-PPP service on their official site.
This guide will show you how to process raw data recorded in the Static mode.
Placing the base
Place your Reach precisely above the marked point on the tripod and level it. You can learn more about placing Reach in the Choosing base setup method tutorial.
Recording RINEX logs on Reach
To record logs for NRCan CSRS-PPP, perform the following steps:
Go to the Logging screen.
Enter the log name.
Select the CSRS preset.
tipWhile recording in the RINEX format, you can log the UBX file as a backup. The UBX file can be used to adjust RINEX file settings in the Converter tool in Emlid Studio. You can enable logging in the UBX format in the logging settings in Emlid Flow.
Tap Apply.
tipYou can start recording automatically when your receiver is turned on. Check the Autostart field on the Common settings screen.
Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
noteNRCan CSRS-PPP requires recording the data for at least 4 hours to get the best accuracy.
To finish recording logs, tap the End recording button.
cautionWait for data processing to finish.
Downloading logs
Go to the Recorded logs section at the bottom of the Logging screen.
Submitting data to NRCan CSRS-PPP service
Once the logs are downloaded, export them to your PC in a preferred way and submit the data to NRCan CSRS-PPP for processing.
Go to the NRCan CSRS-PPP official site.
Click the Sign in button and enter your login and password to access the NRCan CSRS-PPP submission page or create a new account in case you don’t have it yet.
In the Email for results field, enter your email address to get the results.
In Processing mode, choose Static.
Choose the datum in which you would like to get the position. In this guide, we will work with the ITRF option.
In the RINEX observation file field, click the Choose file button and browse for the observation file (.**O).
Click the Submit to PPP button to send the file for processing.
NRCan CSRS-PPP will send the file with the solution to your email address.
Assessing NRCan CSRS-PPP results
In the solution report, look for the Estimated Position. There should be a table with 4 rows:
- The first row contains calculated LLH coordinates in the chosen coordinate system.
- The Sigmas row shows an estimated accuracy.
- In the A Priori row, there is a few-meter accurate position taken from the RINEX header.
- The Estimated - A Priori row displays the accuracy from this position specified in the RINEX header.
Setting up obtained base coordinates in Emlid Flow
Open Emlid Flow and connect to the Reach you want to use as a base.
On the Receivers screen, tap Base settings.
Tap the Configure button.
Set the Coordinates entry method to Manual.
Specify the antenna height and enter the coordinates.
- Tap Save.
