How to log data for PPP
This guide shows how to record logs for the Precise Point Positioning services and download them using Emlid Flow.
Precise Point Positioning is a technique that requires processing a raw data log from the standalone receiver for further removing or modeling GNSS system errors to provide a high level of position accuracy.
To learn more about PPP, check the How PPP works article.
Recording RINEX logs on Reach
To record logs for PPP, perform the following steps:
Go to the Logging screen.
Enter the log name.
Select the preset depending on the PPP service you choose.
noteIf you do not know which version of RINEX you need, we recommend using RINEX 3.03. However, make sure the PPP service you choose supports this version of RINEX.
tipWhile recording in the RINEX format, you can log the UBX file as a backup. The UBX file can be used to adjust RINEX file settings in the Converter tool in Emlid Studio. You can enable logging in the UBX format in the logging settings in Emlid Flow.
Tap Apply.
- Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
PPP services requires recording the data for at least 4 hours to get the best accuracy.
- To finish recording logs, tap the End recording button.
Downloading logs
Go to the Recorded logs section at the bottom of the Logging screen.
When the logs are downloaded, you can start working with your data in the PPP service.
