How to log data for OPUS
This guide shows how to record logs for NOAA's Online Positioning User Service (OPUS) and download them using Emlid Flow.
The Online Positioning User Service (OPUS) is provided by the National Oceanic and Atmospheric Administration (NOAA). With OPUS, you may accurately determine the coordinates of a static point mostly on the territory of the US without real-time corrections or a base station nearby.
You can learn more about the NOAA’s OPUS in this guide.
To record logs for OPUS, follow the steps below:
  2. Go to the Logging screen.
  3. Tap the Recorded logs and settings button.
  4. To configure logging, tap the blue gear button.
  5. Enter the log name.
  6. Select the OPUS preset.
  7. Choose the required RINEX format in the Raw data section.
  8. Enter the measured height to the bottom of the receiver in the corresponding field.
  9. Fill in the point's name in the Marker name field.
  10. Tap Apply.
  11. Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
    NOAA’s OPUS requires recording the data for at least 4 hours to get the best accuracy.
  12. To finish recording logs, tap the End recording button.
Downloading logs​
When the logs are downloaded, you can submit the data to NOAA's OPUS for processing.
Further reading​
