How to log data for PPK
This guide shows how to record logs for Post-Processed Kinematic and download them using Emlid Flow.
Post-Processed Kinematic or simply PPK is a technique that requires processing raw GNSS logs from both the base and the rover to receive an accurate positioning track or separate points after the survey.
To learn more about PPK, check the PPK setups overview article.
To record logs for PPK, perform the following steps both on your base and rover:
  2. On the Receivers screen, tap Settings.
  3. Go to GNSS settings and set the update rate to 1 Hz for the base and to 5 Hz for the rover.
  4. Go back to the Receivers screen and tap Logging.
  5. Tap the Recorded logs and settings button.
  6. To configure logging, tap the blue gear button.
  7. Enter the log name.
  8. Choose the required RINEX format in the Raw data section.
  9. Tap Show configuration and select the required satellite systems.
    Make sure that you have chosen the same set of satellite systems both on the rover and the base.
  10. Set the logging interval to Full rate.
  11. Enter the measured height to the bottom of the receiver in the corresponding field.
  12. Leave the Marker name field empty.
  13. Tap Apply.
  1. Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
  1. To finish recording logs, tap the End recording button.
Download logs​
When your logs are downloaded, you can start working with your data in Emlid Studio.
