How to log data for Stop & Go with Emlid Flow
This guide shows how to record logs for Stop & Go with Emlid Flow and download them using Emlid Flow.
Stop & Go with Emlid Flow is a technique that involves the use of a base placed at a known point and a rover attending all unknown points and occupying each one for a short time. This workflow allows you to get separate points from the track of measurements using the logs from the base and the rover and a CSV from the Emlid Flow app.
To learn more, check the Stop & Go with Emlid Flow tutorial.
To record the logs for Stop & Go with Emlid Flow, follow the steps below:
  2. On the Receivers screen, tap Settings.
  3. Go to GNSS settings and set the update rate to 1 Hz for the base and to 5 Hz for the rover.
  4. Go back to the Receivers screen and tap Logging.
  5. Tap the Recorded logs and settings button.
  6. To configure logging, tap the blue gear button.
  7. Enter the log name.
  8. Choose the required RINEX format in the Raw data section.
  9. Tap Show configuration and select the required satellite systems.
    Make sure that you have chosen the same set of satellite systems both on the rover and the base.
  10. Set the logging interval to Full rate.
  11. Use antenna height and enter the measured height to the bottom of the receiver for the base. Don't use it for the rover.
  12. Leave the Marker name field empty.
  13. Tap Apply.
  1. Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar. Now you are ready to collect the points.
    When collecting the points, make sure that you averaged points for your project and export it in the CSV format from Emlid Flow. The CSV (PENZD) format cannot be used for the Stop & Go workflow.
    To learn more about the Collector tool in Emlid Flow, check the Collect points guide.
  2. To finish recording logs, tap the End recording button.
Download logs​
When your logs are downloaded, you can start working with your data in Emlid Studio.
