Stop & Go with Emlid Flow
This tutorial shows how to use the Stop & Go with Emlid Flow workflow in Emlid Studio to get separate points with precise coordinates from the track of measurements.
Stop & Go with Emlid Flow allows you to improve the positions of points collected without a real-time correction link between the base and the rover. This may happen due to the insufficient line of sight, absence of an internet connection, non-availability of the NTRIP service, etc.
The workflow in the field involves the use of a base and a rover attending all unknown points and occupying each one for a short time. The technique can be compared to point collection in RTK, but precise positions of collected points are calculated afterward, not in real time.
Getting started
To get separate points with precise coordinates, you will need the following:
- a RINEX observation file from the base
- a RINEX observation file from the rover
- a RINEX navigation file from the base or from the rover
- a CSV file from Emlid Flow
When collecting points with your Reach using Emlid Flow and exporting your project, ensure the following:
You average the points. If you're using Reach RS3, make sure to disable tilt compensation while collecting points.
You export your project in CSV format. Keep in mind that the CSV (PENZD) format is not compatible with the Stop & Go workflow.
If you recorded raw data in the UBX format or got corrections from the NTRIP service in the RTCM3 format, Emlid Studio will automatically convert them to RINEX using the background conversion feature.
Emlid Studio calculates all solutions using RINEX files from the base and the rover and averages them over time spans using a CSV file from Emlid Flow to provide separate points.
Generating POS file
If you already post-processed RINEX files from the base and the rover and obtained a .pos file, go straight to the Generating corrected CSV section.
First, you need to process RINEX files from the base and the rover to get a POS file. Follow the steps below:
Select the workflow from the drop-down list in the upper-left corner.
Add the RINEX observation file from the rover.
noteThe antenna height will be taken from the CSV file.
Add the RINEX observation file from the base.
Set the base coordinates. Emlid Studio uses the position from the RINEX header by default. If you placed your base over a known point, you can manually enter its coordinates and antenna height, or you can also update the position by dragging in a .pos file created during static processing.
If you use a .pos file created during post-processing, Use the .pos file generated with the One Best solution option in Emlid Studio for the most accurate base position.
Add the RINEX navigation file from the base or rover.
Click Process and wait until a POS file is ready, Emlid Studio will show it on the plot.
If you skipped the steps above, you need to add the POS file manually. Drag and drop it to the PPK solution field.
To generate a corrected CSV, follow the steps below:
Add a CSV file from Emlid Flow and tick the required data quality to choose solutions to be averaged.
noteIf you want to get cm-accurate results, tick Fix only.
Click Start. The result will be shown on the plot.
noteClick the Show result files button to get the resulting corrected CSV file. Emlid Studio creates a copy of the .csv file named “name_of your-file_corrected.csv".
Video guide
Checklist
To ensure successful processing, double-check the following:
- The base station position is in the correct coordinate system.
- The base and rover RINEX files overlap in time.
- The CSV file uses commas as delimiters.
- The CSV file uses the original Emlid Flow header. Avoid PENZD or PNEZD formats, and don't rename the column headers. Standard CSV files exported from Emlid Flow work best.
- You collected points using averaging rather than instant collection.
- File and folder names use UTF-8 characters, including spaces, accented letters, and special characters. Paths are kept short, with files saved to the Desktop if possible.
- Other applications are closed, and enough disk space is available for processing.
