Convert to RINEX
This tutorial shows how to use the Convert to RINEX function in Emlid Studio to convert raw data logs from a receiver to the industry-standard RINEX format.
With the Convert logs to RINEX feature, Emlid Studio allows converting raw data logs to the industry-standard RINEX format. RINEX is a data interchange format for raw satellite navigation system data that facilitates the management and disposal of the receiver's measurements and their offline processing. Raw data collection is necessary for post-processing services that allow you to produce a more accurate result.
The advantage of the RINEX format is that it is designed to evolve and adapt to new types of measurements and new satellite navigation systems.
Getting started​
Convert the following files from your receiver to the industry-standard RINEX format:
  • UBX
  • RTCM
  • RINEX (to the required version)
To convert your files, follow the steps below:
  1. Select the workflow from the drop-down list in the upper-left corner.
  2. Choose the file you want to convert to RINEX.
  3. If necessary, you can adjust the conversion settings. Click the gear icon and set the options you need.
    If you want to process the converted file in OPUS, set the interval to 30 s, check the Time rounding box, and leave only GPS satellites. Then click Save.
  4. Click Convert.
    After converting, you will see the .21O file on the plot. This file contains raw GNSS observation data.
  5. Click the Show files button to show the converted files, Emlid Studio automatically saves them in the original folder.
Checklist​
To convert a UBX file to RINEX successfully, double-check the following:
  • The base station position is in the correct coordinate system.
  • A UBX file recorded with a non-Reach receiver contains raw GNSS observations rather than NMEA messages.
  • File and folder names use UTF-8 characters, including spaces, accented letters, and special characters. Paths are kept short, with files saved to the Desktop if possible.
  • Other applications are closed, and enough disk space is available for processing.
