Placing GCPs in RTK mode
Video guide​
This tutorial will show how to place GCPs with Reach units.
Text guide​
Configure RTK​
If you have 2 Reach RS/RS+, this video will guide you on how to set them up in RTK:
Setting RTK on Reach rover over NTRIP
If you have just one Reach receiver, you need to connect it to NTRIP first. Check the Working with NTRIP guide for more details.
Create a project​
Learn how to create a project in Emlid Flow using the Create or import project guide.
Fix target​
Put your pole in the center of the target.
Level your pole using a bubble level.
Collect points​
To learn how to collect points using Emlid Flow, check the Collect points guide.
Export​
To learn how to export projects, check the Export projects guide.
