Export projects
This guide shows how to export project data from Emlid Flow or Emlid Flow 360 for further use in third-party GIS software.
With Emlid Flow and Emlid Flow 360, you can export your projects as CSV, Custom CSV, DXF, KML, or Shapefile to work with them in third-party GIS software.
Exporting project
To export the project, follow the steps below:
- Emlid Flow
- Emlid Flow 360
Open Emlid Flow and go to the Survey tab.
Find the project you want to export and tap the 3 dots button in the top right corner.
Tap Export.
Choose the format in which you want to export your project and, if necessary, adjust its configuration.
Wait until Emlid Flow finishes to export your project. Save the file depending on the device you use.
Open Emlid Flow 360 and find the project you want to export.
Tap the 3 dots button in the top right corner of the project’s plate. Click Export.
Wait until Emlid Flow 360 finishes to export your project. Save the file depending on the device you use.
Now your project’s data is ready for further use in third-party GIS software.
