Getting started
This guide describes how to start working with the Emlid Flow and Emlid Flow 360 apps.
Accessing the apps
Download the app to your iOS or Android mobile device.
The Emlid Flow app supports devices on Android v7+ and iOS v15+.
Download Emlid Flow
Creating Emlid account
If you don’t have an Emlid account or your data isn’t visible in Emlid Flow 360, do not remove or reinstall the app, as your projects won't be saved. In case of any difficulties, please contact us at support@emlid.com, and we'll be sure to help you out.
Emlid account allows you to sync your projects between Emlid Flow and Emlid Flow 360 as well as between different devices, and instantly save the progress of your survey. You can have access to all your project data, custom coordinate systems, code libraries, and NTRIP profiles across your devices.
Using an Emlid account, you can access our Community forum and Emlid Caster.
To create an Emlid account, follow the steps below:
You don’t need to be connected to the receiver to create an account using Emlid Flow.
  1. Open Emlid Flow and go to the Profile tab.
  2. Tap Emlid account.
  3. Tap the Log in button. You will be redirected to the Emlid account creation page.
  4. To create an account, go to the Sign Up tab.
  5. Type in your email and password in the corresponding fields.
  6. Tap the SIGN UP button.
  7. Verify your email address by following the on-screen instructions.
After you create an Emlid account, log in to Emlid Flow or Emlid Flow 360 to enable data sync between all your devices.
