Placing GCPs in RTK mode
Video guide
This tutorial will show how to place GCPs with Reach units.
Text guide
Configure RTK
If you have 2 Reach RS2/RS2+, this video will guide you on how to set them up in RTK:
Setting RTK on Reach rover over NTRIP
If you have just one Reach receiver, you need to connect it to NTRIP first. Check the Working with NTRIP guide for more details.
Create a project
Learn how to create a project in Emlid Flow using the Create or import project guide.
Fix target
Put your pole in the center of the target.
Level your pole using a bubble level.
Collect points
To learn how to collect points using Emlid Flow, check the Collect points guide.
Export
To learn how to export projects, check the Export projects guide.
