Base and rover setup
This guide shows how to set up two Reach RS/RS+ units as a rover and a base and how to make them work over LoRa radio in RTK mode.
LoRa is a long-range radio technology that lets your Reach base transmit RTK corrections directly to the rover without an Internet connection or external network. It's a reliable option for surveying in remote areas with limited or no cellular coverage. Follow this guide to set up RTK over LoRa radio.
Rename Reach devices​
By default, every Reach RS/RS+ has the same name, and the first thing you need to do is renaming them so it is easier to distinguish between the base and the rover in the field. To rename the units, follow the steps below:
  1. Connect to the Reach RS/RS+ you want to use as a base.
    How to identify Reach RS/RS+?
    When you connect to your Reach, all LEDs will blink simultaneously. If you need to flash LEDs during a survey—tap the cell with your receiver’s name on the Receivers screen and get access to the Flash LEDs button.
  2. Go to Settings and tap Receiver info.
  3. In Receiver and hotspot name, change the name of your Reach to reach-base.
    The name you enter will also be used as a Wi-Fi network label when Reach is in hotspot mode.
  4. Tap Save.
    Use a special sticker from the package to mark the unit.
  5. Do the same with the second Reach RS/RS+. However, use the reach-rover name instead of reach-base.
Set up your base​
Now you need to configure RTK settings and communication over LoRa radio between the base and the rover. Let's start with the base, follow the steps below:
  1. Connect to the base unit.
  2. Go to Settings and tap GNSS settings. Pick each of the satellite systems.
    Choose between GLONASS and BeiDou depending on your location. While GLONASS covers most of the world, BeiDou might be more efficient in the Asia-Pacific region.
  3. Set the GNSS update rate to 1 Hz.
  4. Return to the Receivers screen. On the Base settings screen, go to RTCM3 messages.
  5. Select to output RTCM3 messages as follows:
    • GPS L1 observations at 1 Hz
    • GLONASS L1 observations at 0.5 Hz
    • Galileo MSM7 observations at 0.5 Hz
    • SBAS observations at 0.5 Hz
    • QZSS at 1 Hz
    • Beidou MSM7 observations at 0.5 Hz
    • ARP station coordinates at 0.1 Hz
  6. Tap Apply.
  7. Return to the Receivers screen. On the Base output screen, select LoRa.
  8. Tap the Edit button in the LoRa cell. Select the frequency and set the output power to 20 dBm.
    Make sure to select the appropriate frequency and output power according to your local regulations. In case there are restrictions, frequency band limitations will be applied automatically.
  9. Set the air data rate to 9.11 kb/s. Tap Save.
Now you can proceed to set up your rover unit.
Set up your rover​
To complete configuring RTK settings and communication over LoRa radio between the base and the rover, you need to set up your rover. Follow the steps below:
  1. Connect to the rover unit.
  3. Select the same satellite systems as for the base and make sure you have the following settings:
    • Positioning mode is Kinematic.
    • GPS Ambiguity resolution mode is Fix-and-hold.
    • GLONASS Ambiguity resolution mode is ON.
    • GNSS update rate is set to 5 Hz.
  4. To configure the LoRa radio on the rover unit to receive the corrections, return to the Receivers screen and tap Correction input.
  5. Select LoRa. Set the same frequency and air data rate as for the base. Tap Save.
To make sure that corrections are passing from the base to the rover, you can put both receivers by the window for a few minutes to provide the sky visibility. After that, open Emlid Flow, connect to the rover and go to the Status screen. Scroll down to the Corrections section and make sure that your rover is receiving corrections.
Place Reach RS/RS+ units​
When you have configured settings on both the base and rover, you are ready to go outside to place the base and complete the setup process. For the field works, you will need a tripod and a survey pole. To place the units, follow the steps below:
Before placing the base, make sure that you are in an open area with a clear sky view. This will ensure good signal reception and a fair number of available satellites.
  1. Mount the Reach RS/RS+ base.
  2. Accurately level the tripod.
  3. Put the rover on the pole.
  4. Attach the LoRa antennas to both units.
  5. Turn on the receivers.
To learn more about placement, check the Placement guide.
After placing the base on the tripod, you can complete its setup:
  1. Connect to the base.
  2. On the Receivers screen, tap Base settings.
  3. To configure base settings, tap the Configure button.
  4. Select Average SINGLE as the base coordinates entry method and set the averaging time. Tap Save.
    Do not move the base while Reach is accumulating data.
    The base position is averaged automatically every time the receiver turns on.
After accumulating the data, you will see averaged coordinates in the Base marker section. Now your base is set up and transmits corrections to the rover.
To learn more about methods of placing the base, check the Placing the base guide.
View results​
When you have completed your RTK setup over LoRa radio, you can see the current solution status in the top right corner of the Emlid Flow app:
  • SINGLE means that the rover has found a solution relying on its own receiver and base corrections are not applied. Precision in standalone mode is usually at the several-meter level.
  • FLOAT means that the rover receives the base station's observation data and position but cannot resolve ambiguities needed to calculate its position with centimeter-level accuracy. In this case, the positioning accuracy can vary from a few centimeters to about 1 meter.
  • FIX means that the rover using corrections from the base resolved the ambiguities in its positional calculation and achieved the solution with the centimeter-level precision.
After a short period of time, the rover gets a fixed solution. In good environments, it will take a couple of minutes to get a fixed solution. In tough conditions, it may take a little longer. Once the rover gets FIX, you are all set for surveying.
You can also find the current solution status as well as your position in real time on the Status screen.
When you learn how to set up RTK over LoRa radio, you can also check how to connect your Reach to the Internet and work with NTRIP service.
