Calculate inverse
Unlock the full set of features for topo, set-out, and as-built surveys
This guide explains how to use the Inverse tool in Emlid Flow and Emlid Flow 360 to calculate coordinate geometry data such as
area
Area of an object is the total amount of space enclosed by its shape on flat surface.
, distance,
azimuth
Direction (azimuth) of a line AB, or from point A to B, is a horizontal angle in degrees, measured at point A clockwise between the direction to the north and the direction to point B.
, and more for known points.
The Inverse tool in Emlid Flow and Emlid Flow 360 allows you to calculate geometry data for existing points. The tool can assist you in such projects as planning civil or utility engineering works and monitoring construction progress.
The software calculates the following values based on the number of input points:
When you select two and more points:
  • Direction
    True North azimuth
    True North azimuth is the angle ranging from 0 to 360 degrees measured clockwise between True North and the direction to a point of interest.
    Grid North azimuth
    Grid North azimuth is the angle measured clockwise between a line parallel to the central meridian, and the direction to a point of interest (a straight line between two points on the projection flat plane).
  • Slope distance
    Slope distance from point A to point B is the length of the straight line AB, measured along the slope, taking the height difference between the points into account.
    Slope Ground distance
    Ground distance is the distance measured on the actual surface of the Earth, taking the mean elevation of the measured points into account.
    Slope Grid distance
    Grid distance is the distance measured on the projection flat plane.
  • 2D distance (
    2D Ground distance
    2D Ground distance between points A and B is the length of the shortest AB line on the surface of the ellipsoid.
    2D Grid distance
    2D Grid distance between points A and B is the length of the straight line AB on a flat plane.
  • Height difference
  • Grade
    Grade of a line is the measure of its steepness, with larger values standing for steeper slopes and 0% indicating a horizontal line.
  • Delta East
    Delta E/N between points A and B is the difference in their coordinates along the corresponding Easting and Northing axes.
    (for points in a local CS only)
  • Delta North
When you select three and more points:
  • Slope distance
    Slope Grid distance
  • 2D distance (
    2D Ground distance
    2D Grid distance
  • Area
  • Slope perimeter
    Slope perimeter of an enclosed object is the sum of slope distances of its sides with the height difference consideration.
  • 2D perimeter
    2D perimeter of an enclosed object is the sum of 2D distances of its sides without the height difference consideration.
Depending on the
coordinate system
(CS) used in your project, different distance and azimuth types are used in the calculations:
CS typeDistance typeAzimuth type
Global CS
Ground distance
True North azimuth
Local CS
Grid distance
Grid North azimuth
See our Introduction to coordinate systems guide to learn more about distance and azimuth types in different CSs.
When calculating
area
in a local
coordinate system
, the software applies a variation of the Shoelace formula, which approximates the
area
using trapezoids:
Area
in a global
coordinate system
can be calculated for ellipsoid (on the ellipsoid surface) or ground (at the mean ground elevation). We use the method described in section 6 of Algorithms for geodesics by C. F. F. Karney (2013).
To apply the Inverse tool in the Emlid Flow app, follow these steps:
  1. Open the project in Emlid Flow.
  2. Tap the tools button at the bottom left corner of the screen.
  3. Tap Inverse.
  4. Select the points you want to calculate the inverse for from the map or Objects list.
    In Emlid Flow & Emlid Flow 360 you can also find the point-to-point, line, and closed line information for each line. To see this information, just tap on the line.
  5. Click Review to see the calculated results. To calculate results for more than two points, use the arrow buttons to switch to a different set of two points.
    The displayed results will be different depending on the selected points. If you select 2 points, you'll see the point-to-point calculations. If you select 3 points, you'll also see the calculations on the area, slope perimeter, etc.
    You can only use Closed line and Line for geometry measurements. It is not possible to import or export them as geometrical figures.
    You can change the order of the points in the Inverse section by dragging and dropping them. To delete a point, tap the delete button.
  6. To exit the Inverse calculation mode, tap the close button in the upper-right corner.
Video guide
Further reading
