Power supply and operation
Reach RS4 / RS4 Pro has a built-in Li-Ion battery that provides up to 16 hours of autonomous operation. The maximum power consumption of the receiver is 10 W.
Charging over USB​
You can power and charge your Reach RS4 / RS4 Pro using the USB Type-C cable (PD) with the following power sources:
  • A power bank
  • A USB wall adapter
Powering Reach RS4 / RS4 Pro from external bottom connector​
Reach RS4 / RS4 Pro can automatically turn on and off when the power is supplied to the device via an external 8-pin bottom connector, provided the input voltage is within the recommended range of 6–36 V.
