How to set up Reach RS3 as base for Autel EVO II Enterprise
This guide shows how to set up Reach RS3 as a base for the Autel EVO II Enterprise drone to geotag drone images for further mapping in photogrammetry software.
It is also possible to use the Autel EVO II RTK Series drone with Reach RS3 base.
Learn more about RTK and PPK in the guides below:
Autel EVO II Enterprise uses NTRIP to receive corrections, which allows you to use Reach as a base station. Reach can send NTRIP corrections via Emlid Caster through the Internet or using the Local NTRIP option in Emlid Flow without connection to the Internet.
To use the Local NTRIP option, the base and the rover should be connected to the same Wi-Fi network.
To set up your Reach as a base for the Autel EVO II Enterprise drone, you will need the following:
- Autel EVO II Enterprise drone as a rover
- Controller
- Reach RS3 as a base
- Internet connection on both Reach RS3 and Autel Smart Controller if you use Emlid Caster
- Access to Emlid Caster
Wokrflow
Set up Reach RS3 as base
Reach RS3 can send NTRIP corrections via Emlid Caster or using the Local NTRIP option in Emlid Flow. The difference is that Emlid Caster requires an Internet connection, and Local NTRIP allows you to set up RTK without an internet connection. Select the method depending on your use case and follow the steps below.
Set up Reach RS3 as base using Local NTRIP
To set up your Reach as a base for the Autel EVO II Enterprise drone using the Local NTRIP option in Emlid Flow, follow the steps below:
tipLearn more about base placement and setup in the Placement and Choosing base setup method articles.
Tap Base output and select the Local NTRIP option.
Tap the Information button to access the page with rover credentials.
Connect Autel Smart Controller to the same Wi-Fi network as your Reach.
To ensure proper connection, keep the distance between the drone’s controller and your base within several meters.
Set up Reach RS3 as base using Emlid Caster
To set up your Reach as a base for Autel EVO II Enterprise using Emlid Caster, you need to get access to Emlid Caster and get NTRIP credentials. Follow the steps below:
Access Emlid Caster and get NTRIP credentials for both base and rover.
tipLearn more about base placement and setup in the Placement and Base setup guides.
Connect your Reach to the Internet.
tipTo learn more about connecting your Reach RS3 to the Internet, check the following guides:
Tap the Edit button and insert the NTRIP credentials for the base.
Once you place and set up your base, you can proceed to the drone’s setup.
Set up Autel EVO II Enterprise as rover
To set up your Autel EVO II Enterprise as a rover, follow the steps below:
Attach the RTK Module to your drone.
tipSkip this step, if you use the Autel EVO II RTK Series drone.
Connect the controller to your drone.
Open the Autel Explorer app. Tap the Camera button.
To open the Settings screen, tap the gear icon in the top right corner.
Go to the RTK screen.
Turn on the RTK Aircraft Feature option. In RTK connection options, choose Custom Network RTK option and fill in the NTRIP credentials.
noteFill in the credentials you obtained when accessing Emlid Caster or enabling the Local NTRIP option in Emlid Flow. Make sure that you use the credentials for the rover.
Tap Login.
The login success message will appear if the base is successfully connected. RTK Network Status should change to the Connection successful state.
Perform Flight
When you set up communication between your Reach and a drone, you can perform the flight. Provide Autel EVO II Enterprise with a clear sky view and proceed to the mission.
Once the flight is completed, you can download the geotagged images and use them for further mapping in photogrammetry software.
To create a map using Pix4DMapper, check the Creating the map in Pix4Dmapper tutorial.
Credits
We want to thank Dave Pitman for sharing his experience of using the Autel Robotics drone as a survey tool with Reach RS2/RS2+.
