DJI RTK drone and Reach RS3 base integration
This guide shows how to set up your Reach RS3 as a base for DJI RTK drones like Phantom 4 RTK, Mavic 3E, and Matrice 300 RTK to geotag drone images for further mapping in photogrammetry software.
Learn more about RTK and PPK in the guides below:
DJI RTK drones use NTRIP to receive corrections which allows you to use Reach RS3 as a base station. Reach can send NTRIP corrections via Emlid Caster through the internet or using the Local NTRIP option in Emlid Flow without connection to the internet.
To set up your Reach RS3 as a base for DJI RTK drone, you will need the following:
- DJI RTK drone with GS RTK or Pilot 2 as a rover
- Controller
- Reach RS3 as a base
- Internet connection on both devices if you use Emlid Caster
- Access to Emlid Caster
In this guide, we will use DJI Phantom 4 RTK drone, but the process is the same for the other DJI RTK drones.
Video tutorial
The video below covers the process of setting up Reach RS2/RS2+ as a base for the DJI Phantom 4 RTK drone using Emlid Caster. The process is the same for Reach RS3.
This video doesn’t cover the process of setting up Reach as a base for the DJI Phantom 4 RTK drone using the Local NTRIP option. You can check this workflow in the Set up Reach RS3 as Base section below.
Text tutorial
The text below covers the process of setting up Reach RS3 as a base for DJI RTK drone using Emlid Caster through the internet or the Local NTRIP option in Emlid Flow.
Set up Reach RS3 as base
Reach RS3 can send NTRIP corrections via Emlid Caster or using the Local NTRIP option in Emlid Flow. The difference is that Emlid Caster requires an internet connection, and Local NTRIP allows you to set up RTK without an internet connection. Select the method depending on your use case and follow the steps below.
Set up Reach RS3 as base using Local NTRIP
This setup will work for your DJI RTK drone only if it supports a Wi-Fi connection.
To set up your Reach as a base for the DJI RTK drone using the Local NTRIP option in Emlid Flow, follow the steps below:
tipLearn more about base placement and setup in the Placement and Choosing base setup method articles.
Tap Base output and select the Local NTRIP option.
Tap the Information button to access the page with rover credentials.
Connect your controller to the same Wi-Fi network as your Reach.
noteTo ensure proper connection, keep the distance between the drone’s controller and your base within several meters.
Set up Reach RS3 as base using Emlid Caster
To set up your Reach RS3 as a base for DJI RTK drone using Emlid Caster, you need to get access to Emlid Caster and get NTRIP credentials. Follow the steps below:
Access Emlid Caster and get NTRIP credentials for both base and rover.
tipLearn more about base placement and setup in the Placement and Choosing base setup method guides.
Connect your Reach to the internet.
tipTo learn more about connecting your Reach RS3 to the internet, check the following guides:
Tap the Edit button and insert the NTRIP credentials for the base.
Once you place and set up your base, you can proceed to the drone’s setup.
Set up DJI RTK drone as rover in GS RTK
If you're using a DJI Mavic 3 Enterprise Series drone or a newer model, refer to the section below for setup instructions in the new controller app, Pilot 2.
To set up DJI Mavic 3 Enterprise Series drone or a newer model in Pilot 2, follow the steps below:
Connect the controller to your drone.
Open GS RTK.
Select Plan or Fly menu. If you choose Plan, select a planning method.
Open Settings by tapping the 3 dots icon in the top right corner.
Go to the RTK Settings tab.
In RTK Service Type, choose Custom network RTK and fill in the NTRIP credentials form.
noteFill in the credentials you obtained when accessing Emlid Caster or enabling the Local NTRIP option in Emlid Flow. Make sure that you use the credentials for the rover.
Tap the Connect button. The "Network RTK server connection successful" message will appear. That means that the base is successfully connected.
Set up other DJI drones as rover in Pilot 2
To set up your DJI RTK rovers , follow the steps below:
Open Pilot 2.
From the Drone Settings menu in Flight Dashboard, tap RTK.
Choose either Custom Network RTK or D-RTK 2 Mobile Station as the RTK source. If using a custom RTK service, enter the required connection details and tap Start Transmitting.
When the RTK connection is successfully established, all status indicators turn green, including the RTK icon.
Perform Flight
When you set up communication between your Reach RS3 and a drone, you can perform the flight. Provide your DJI RTK drone with a clear sky view and proceed to the mission.
Once the flight is completed, you can download the geotagged images and use them for further mapping in photogrammetry software.
To create a map using Pix4DMapper, check the Creating the map in Pix4Dmapper tutorial.
