Firmware reflashing
You do not need to reflash the firmware unless you want to bring your Reach to its initial state. This will delete all the data on your unit. The recommended method to update your receiver is to use the updater tool in Emlid Flow.
This tutorial shows how to reflash Reach RS+/RS firmware using Reach Firmware Flash Tool.
Most new features are released via the Emlid Flow app and can be updated simply via its interface.
Reach Firmware Flash Tool installation​
Download and install Reach Firmware Flash Tool.
WindowsUbuntumacOS
Download [EXE, 158 MB]Download [DEB, 116 MB]Download [DMG, 138 MB]
Windows installation​
We recommend that you disable any antivirus or security software on your computer before installing Reach Firmware Flash Tool. Such programs may delete important files that the tool needs to work correctly.
  1. Double-click on the downloaded file.
  2. Follow the instructions to install Reach Firmware Flash Tool on your PC.
  3. Reboot your PC.
Ubuntu installation​
We recommend using the terminal to install the Flash Tool on your PC.
If your Flash tool version is 1.7.1 or older, to update to the latest version you will need to add the new GPG key. Run the sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 90F3927E0416B765 command in the terminal.
  1. Press Ctrl+Alt+T to open the terminal.
  2. Navigate to the directory with the downloaded file with the cd ~/Downloads command.
  3. Run sudo apt install ./reach-firmware-flash-tool_1.15.1_amd64.deb to start the installation.
    Please confirm adding the current user to plugdev and dialout groups during the installation process. In case of a negative answer, the application might not work as expected.
  4. Reboot your PC.
macOS installation​
  2. Follow the instructions to install Reach Firmware Flash Tool on your Mac.
  3. Drag the application icon to the Applications folder.
Reflash your Reach RS/RS+​
Reflash your Reach following the steps below:
  1. Open Reach Firmware Flash Tool and choose Reach RS+ or Reach RS.
    You can also press the Return/Enter button to proceed to the next step.
  1. Connect Reach in Firmware mode.
    How to switch your Reach to Firmware mode
    Make sure that Reach RS+ is turned off and perform the following steps:
    • Press and hold the power button.
    • Plug the USB cable into the PC.
    • Release the power button.
    • All LEDs should blink several times simultaneously, and then start blinking one after another.
  2. Click Download and flash the latest version. The tool will download the latest firmware image and begin the flashing process.
    Make sure you have enough disk space. Reach Firmware Flash Tool creates 2 folders: one to download the image and another one to unpack it. Once you close the Flasher tool, the folder with the unpacked image will be deleted.
  3. Wait until the end of the flashing process.
  4. Wait until Reach reboots after reflashing. When Reach successfully reboots, you will see the "Reach is flashed and ready to use" message.
    Do not unplug your unit on this step.
  5. Set up your Reach.
    You can check the First setup guide to ease the setup process.
