How to access Reach Panel from a web browser
This guide explains how to access Reach Panel in a web browser to work with the Reach device.
You can access your Reach from a PC using Reach Panel. Reach Panel is a web interface that allows you to work with Reach devices in a browser. For example, you may want to download heavy logs directly to your laptop for post-processing in your desktop application, or you may want to preset your Reach from your laptop before working in the field.
Your Reach and PC must be connected to the same Wi-Fi network.
To access Reach Panel to work with your Reach, you need an IP address for your device. In hotspot mode, your Reach has a default static IP address of 192.168.42.1. When you connect your Reach to a Wi-Fi network, your receiver is assigned a dynamic IP address.
To access your Reach in Reach Panel, follow the steps below:
  1. Open the Emlid Flow app.
  2. Find your Reach in the list of available devices and connect to it. If there is only one available device, Emlid Flow will automatically connect to it.
  3. Find an IP address under the name of your Reach. Type this IP address in the address bar of your browser to open Reach Panel.
You can open Reach Panel from your phone's browser. To do this, tap the name of your Reach to open a menu, then go to Reach Panel.
You are now ready to work with your Reach in the Reach Panel web interface.
