How to restore initial settings
This guide explains how to restore the initial settings on your Reach RS2/RS2+.
You can restore the initial settings on your Reach using the Restore initial settings option in Emlid Flow. The option allows restoring GNSS settings, Correction input, Base output, and Base mode to an initial state. All other settings, including receiver name, Wi-Fi settings, logs, and projects will be saved.
To restore the initial settings on your receiver, follow the steps below:
Connect to your Reach via Emlid Flow.
Tap Settings and go to the Troubleshooting section.
Tap Restore initial settings.
Tap the Restore settings button.
Once it’s done, you will see that the button becomes gray and its name changes to Done.
After that, you can proceed to set up your Reach.
