How to log data for PPP
This guide shows how to record logs for Precise Point Positioning (PPP) and download them from Reach RS/RS+ using Emlid Flow.
Precise Point Positioning is a technique that requires processing a raw data log from the standalone receiver for further removing or modeling GNSS system errors to provide a high level of position accuracy.
To learn more about PPP, check the How PPP works article.
Recording RINEX logs on Reach
Only NRCan CSRS-PPP and IBGE-PPP services support PPP for single-band receivers. With Reach RS/RS+ you will get an accuracy of about 30 cm.
To record logs for PPP, perform the following steps:
  2. Go to the Logging screen.
  3. Tap the Recorded logs and settings button.
  4. To configure logging, tap the Settings button.
  5. Select the preset depending on the PPP service you choose.
  6. Choose the required RINEX format in the Raw data section.
    If you do not know which version of RINEX you need, we recommend using RINEX 3.03. However, make sure the PPP service you choose supports this version of RINEX.
    While recording in the RINEX format, you can log the UBX file as a backup. UBX file can be used to adjust RINEX file settings in the Converter tool in Emlid Studio. You can enable logging in the UBX format in the logging settings in Emlid Flow.
  7. Enter the measured height to the bottom of the receiver in the corresponding field.
  8. Fill in the point's name in the Marker name field.
  9. Tap Apply.
    You can start recording automatically when your receiver is turned on. Check the Autostart field on the Raw data settings screen.
  10. Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
    PPP services require recording the data for at least 4 hours to get the best accuracy.
  11. To finish recording logs, tap the End recording button.
Downloading logs
When the logs are downloaded, you can start working with your data in the PPP service.
Further reading
