How to set up RTK over Emlid NTRIP Caster
This guide shows how to set up your Reach RS3 base and rover to work in RTK over Emlid Caster.
Emlid Caster is a cloud service that implements the NTRIP protocol and acts as a line of communication between connected to the internet GNSS receivers. With Emlid Caster, you can easily transmit RTK corrections—connect your base and rover to the same mount point, an automatically generated correction stream, and start surveying.
Get access to Emlid Caster
To get access to Emlid Caster, follow the steps below:
Go to caster.emlid.com.
Sign up.
noteYou can sign in using your Emlid account.
Once you sign up, you will access the page with NTRIP credentials for both base and rover. From this moment, you can use these credentials to connect your base and rover to a mount point.
Connect your base to mount point
To connect your base to a mount point, follow the steps below:
Activate the mount point you want to use by turning on the toggle.
Set up your base to send corrections over NTRIP using the obtained credentials:
- Address
- Port
- Password
- Mount point
noteMake sure you configured your base to output corrections via NTRIP.
Once you successfully connect your base, you will see the ONLINE notification next to the mount point name.
Connect your rover to mount point
To connect your rover to a mount point, follow the steps below:
Access the rover's credentials.
noteOnce you activate the mount point for the base, you will see it in the rover's credentials.
Set up your rover to get corrections over NTRIP using the obtained credentials for the rover:
- Address
- Port
- User name
- Password
- Mount point
noteMake sure you configured your rover to receive corrections from the base via NTRIP.
Once you successfully connect your rover, you will see the ONLINE notification and the number of the connected rovers in the My rovers section.
To ensure successful corrections transmitting, double-check the credentials you entered on both base and rover.
When set up and connected both base and rover to the mount point, you are all set for the survey.
