Power supply and operation
Reach RS3 has a built-in Li-Ion battery that provides 18 hours as an RTK rover with tilt compensation and 22 hours of autonomous operation when logging data.
Charging over USB
You can power and charge Reach RS3 via the USB-C cable using the following power supplies:
- A power bank
- A USB wall adapter
Powering Reach RS3 from external bottom connector
Reach RS3 can automatically turn on and off when the power is supplied to the device via an external 9-pin bottom connector with a voltage in the range from 6 V to 40 V. You can enable this feature in the Emlid Flow settings.
The receiver requires 5W to charge. Operation requires an average of 7.5 W (maximum 10 W).
