Placing the base
This tutorial will show you how to set up a Reach RS2/RS2+ base over a known point. The workflow is the same for Reach RS/RS+.
Figure 1
Figure 2
Ways to set the base
Base setup method | Accuracy | Requirement | Observation time | Processing time | Cost |
Manual, on a known point | same as the point | Known point | 0 min | Immediate, no processing required | Free |
Average single position | ~2.5 m | - | <5 min | Immediate, processing on Reach | Free |
RTK FIX position | H:7mm+1ppm V:14mm+1ppm | NTRIP stream from base <10km for RS/RS+ <60km for RS2 | <5 min | Immediate, processing on Reach | Free/$$ depending on local provider |
RTK Float position | 1.0m | NTRIP stream from base <10km for RS/RS+ <60km for RS2 | <15 min | Immediate, processing on Reach | Free/$$ depending on local provider |
Static processing | H:4mm+0.5ppm V:8mm+1ppm | RINEX logs from base <30km for RS/RS+ <100 km for RS2 | ~1 h | 15min on PC after log from reference station available, usually posted hourly | Free/$$ depending on local provider |
Precise Point Positioning | ~30cm for RS/RS+ ~1-2cm for RS2 | - | ~4 h | In ~24h after submitting logs to NRCan online service | Free |
Manual
Pay attention and carefully place the base over a known point and measure the height of the antenna from the mark. It will help to avoid shifts from the absolute position and keep measurements accurate. Refer to Placing Reach RS/RS+ in the field for detailed instructions.
Average
Averaged single
Figure 3
If you only need accurate relative positioning the easiest way is to average the position using single solution. Just physically mark the point on the ground and save coordinates to manual in Emlid Flow. Day-to-day result would look almost identical to those obtained using NTRIP corrections.
Averaged FLOAT and FIX
Static processing
General steps:
Enable logging of raw data and record a log for about an hour.
Export the log with the collected data from Emlid Flow to your PC.
Refer to the Static processing tutorial. It will take you about 15 minutes to calculate the position of your base station.
After you get the coordinates you may enter them manually in the Base coordinates section. Comparing the position obtained using Static processing to the averaged position and applying corrections to the collected data is the way to compensate the shift shown in the example in Figure 2.
General steps:
Enable logging of raw data and record log for a few hours.
Export log with the collected data from ReachView to your mobile device or PC.
Upload the collected file to PPP service (for example NRCan).
After you get the coordinates you may enter them manually in Base coordinates section.
When placing your Reach RS/RS+ in the field, make sure your Reach device is placed precisely above the marked point on the tripod and leveled. If you are setting up base coordinates manually, you need to measure the antenna height offset. Follow the steps below:
Measure the distance between the mark and the bottom of your Reach (h on Figure 5).
Specify the measured distance in Emlid Flow. It will automatically calculate the antenna height.
Reach RS/RS+ antenna heightFor Reach RS/RS+, the antenna height is the distance between the mark and the bottom of the receiver (h on Figure 5) plus the receiver's height to the antenna reference point (ARP) which is equal to 65 mm and automatically added by Emlid Flow.
Figure 5
When you securely placed your Reach over the mark, you are ready to set or determine its position.
