How to log data for PPK
This guide shows how to record logs for Post-Processed Kinematic and download them from Reach RS/RS+ using Emlid Flow.
Post-Processed Kinematic or simply PPK is a technique that requires processing raw GNSS logs both from the base and the rover to receive an accurate positioning track or separate points after the survey.
To learn more about PPK, check the How PPK works article.
Recording RINEX logs on Reach
To record logs for PPK, perform the following steps on both base and rover:
  2. On the Receivers screen, tap Settings.
  3. Go to GNSS settings and set the update rate at 1 Hz for the base and at 5 Hz for the rover.
  4. Go back to the Receivers screen and tap Logging.
  5. Tap the Recorded logs and settings button.
  6. To configure logging, tap the Settings button.
  7. Choose the required RINEX format in the Raw data section.
    While recording in the RINEX format, you can log the UBX file as a backup. UBX file can be used to adjust RINEX file settings in the Converter tool in Emlid Studio. You can enable logging in the UBX format in the logging settings in Emlid Flow.
  8. Tap Show configuration and select the required satellite systems.
    Choose GLONASS or BeiDou depending on your location. While GLONASS covers most of the world, BeiDou might be more efficient in the Asia-Pacific region.
    Make sure that you have chosen the same set of satellite systems both on the rover and the base.
  9. Set the logging interval at Full rate.
  10. Enter the measured height to the bottom of the receiver in the corresponding field.
  11. Leave the Marker name field empty.
  12. Tap Apply.
You can start recording automatically when your receiver is turned on. Check the Autostart field on the Raw data settings screen.
  1. Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
  1. To finish recording logs, tap the End recording button.
Download logs
When the logs are downloaded, you can start working with your data in Emlid Studio.
