How to log data for OPUS
You can record logs for OPUS only on Reach M2 as the service supports only multi-band receivers.
This guide shows how to record logs for NOAA's Online Positioning User Service (OPUS) and download them using Emlid Flow.
Online Positioning User Service (OPUS) is provided by the National Oceanic and Atmospheric Administration (NOAA). With OPUS, you may accurately determine the coordinates of a static point mostly on the territory of the US without real-time corrections or a base station nearby.
You can learn more about the NOAA’s OPUS in this guide.
Recording RINEX logs on Reach
To record logs for OPUS, follow the steps below:
Go to the Logging screen.
Select the OPUS preset.
tipWhile recording in the RINEX format, you can log the UBX file as a backup. UBX file can be used to adjust RINEX file settings in the Converter tool in Emlid Studio. You can enable logging in the UBX format in the logging settings in Emlid Flow.
Tap Apply.
tipYou can start recording automatically when your receiver is turned on. Check the Autostart field on the Raw data settings screen.
Enable log recording by tapping the Start recording button. The red recording icon will appear in the status bar.
noteNOAA’s OPUS requires recording the data for at least 4 hours to get the best accuracy.
To finish recording logs, tap the End recording button.
- Turn off the receiver by using the button.
Before pulling out the cable from a power source, wait for at least 15 seconds for the system to shut down properly.
Download logs
Go to the Recorded logs section at the bottom of the Logging screen.
When the logs are downloaded, you can submit the data to NOAA's OPUS for processing.
