Aller au contenu principal
État des LED
remarque
LED functionality is available with firmware version 2.7.0 and newer.
Reach Module boot LED sequence​
Reach Module LED is an RGB LED that cycles through a simple pattern:
Network state -> App state
During boot Reach Module will go through 3 steps:
  • Network scan
  • Time sync
  • Emlid Flow launch
Network scan​
During boot, Reach Module enters a network scan state in which it will try to connect to any known Wi-Fi networks it can find. This might result in connecting to a previously added network or creating its own hotspot.
Network stateDemo
Scanning
Client Wi-Fi mode
Hotspot Wi-Fi mode
Time sync​
After network configuration is done, magenta blinks will be added to the LED. They are shown during time sync.
attention
The app will not launch until the time sync is complete. Internet connection allows this to happen automatically, but in hotspot mode Reach Module requires a connected antenna with some satellite visibility.
Emlid Flow launch and operation​
After the time sync is done, the magenta blinks stop and Emlid Flow is launched. Green solid light will take its place, showing app start. You can see several additional states:
App stateDemo
Normal app operation
Point collection
App internal error
LED Behavior​
The table below demonstrates possible flash patterns describing various states of the receiver.
Reach Module StateTime SyncNetworkApp StatusSequence Demo
OFF
Lack of power
Blinks each 10-15 sec
Network scan
Fast blinks
Time sync in client Wi-Fi mode
Solid
Solid
Time sync in Hotspot mode,
sattelite visibility is required
Solid
Solid
App running,
Wi-Fi client mode
Solid
Solid
App running,
hotspot mode
Solid
Solid
Point collection,
assuming Reach is in Hotspot mode
Solid
Fast blinks
Internal error,
Solid
Solid
