LED status
Reach RS3 has several LEDs that are used as status indicators for various parts of the system.
Battery
The lights above the power button indicate the battery charge level. If the loading animation is over, then you can connect your phone to Reach.
Network
During boot, Reach RS3 enters a network scan state and searches for known networks to connect to. If it doesn't find a known network, it switches to hotspot mode.
RTK Status
This LED is used to display Emlid Flow RTK status. RTK status has two colors: white and blue. White indicates incoming corrections, and blue indicates whether outgoing corrections are enabled. If the outgoing ones are turned off, there will only be a white LED. If enabled, the light will switch between white and blue every two seconds.
Power
The LED on the Power button shows whether the receiver is on or off. and the point collection process.
