How to connect your base to a mount point
When transmitting corrections using the caster, the maximum distance for NTRIP is limited only by the maximum distance for RTK.
This guide shows how to connect your base to a mount point. To connect your base to a mount point, follow the steps below:
Add a new mount point by clicking + New mount point.
noteIf you already have mount points, select a mount point you want to use.
Get your NTRIP credentials for the base. They are generated automatically.
tipYou can edit credentials, give descriptions, or delete mount points. Click the pencil icon next to the toggle.
Activate the mount point you want to use by turning on the toggle.
Set up your base to send corrections over NTRIP using the obtained credentials:
- Address
- Port
- Password
- Mount point
If the connection failed, do the following:
- Double-check the credentials you entered.
- Make sure that you configured correction output via NTRIP on your base.
If you want to connect more bases to mount points, repeat the same steps.
Once you successfully connect your base, you will see the BASE ONLINE notification next to the mount point name.
From this moment, your client can connect their rovers.
