Set up coordinate system from library
We recommend setting up the projects indoors before the survey as some
coordinate systems
require additional downloads in Emlid Flow.
This guide shows how to set up a
coordinate system
for your project in Emlid Flow or Emlid Flow 360.
You can only configure the
coordinate system
while creating a new project.
Emlid Flow and Emlid Flow 360 contain a library of ready-to-use local
coordinate systems
and vertical datums for specific countries. If you need additional information on the
coordinate system
in your country, check the step-by-step guides:
If you can't find your country or region in the list, contact us at support@emlid.com.
To show you all the steps, we will walk you through the example of configuring a
coordinate system
for Switzerland.
Setting up coordinate system
While creating a project, follow the steps below:
  1. On the New project screen, tap Coordinate system.
  2. Search the required coordinate system by its name, country, or code.
    We enter Switzerland and pick CH1903 / LV03.
    To learn more about the suggested coordinate system, tap the info icon next to the system. Depending on the chosen coordinate system, the screen can contain the following information:
    • Datum and its reference ellipsoid with parameters
    • Global datum
      Global datum is an ellipsoidal coordinate reference system that is used by the receiver to measure coordinates before any transformations are applied.
    • Projection type and its parameters
    • Transformation type and its parameters
  3. Once you’ve selected the coordinate system, go to the Vertical datum section. The app will show you available vertical datums and corresponding geoids. Choose the one you need.
    We select LHN95 height.
Make sure that the coordinate system of your project and the base or
NTRIP
The Networked Transport of RTCM via Internet Protocol or NTRIP network is an alternative source of corrections. NTRIP allows your rover to accept corrections over the Internet with no need for the second local receiver acting as a base. A reference station collects data, then sends it to NTRIP caster, where it is retransmitted through the Internet port to the client rover connected via a particular port and authorized.
you use are in the required datum. You can find the required datum for your country in the countries list. You can also find this information in your project in Emlid Flow.
You can continue creating the project for survey.
Editing coordinate system
In Emlid Flow 360, you can change a coordinate system for your project. Follow the steps below:
  1. Open the project in Emlid Flow 360.
  2. Tap the three-dot button in the upper-right corner, then tap Edit info.
  3. Tap the Edit button in the Coordinate system section.
  4. Select a suitable option to set a new CS.
  5. After you’ve selected the new CS, tap Save to apply the changes.
Further reading
