ReachView 3 Android changelog
7.1
Added
- We added new vertical datums for Columbia (Colombia GeoCol2004 height) and Azores Islands (Portugal GEODAZ2014 height).
Fixed
- Minor fixes and visual improvements.
7
Added
- We are happy to introduce the next major update for the app—Cloud sync! Log into your Emlid Account and store your projects, coordinate systems, and NTRIP profiles in cloud storage. No longer worry about losing data if the hardware fails; work with multiple mobile devices with ease! The app will sync your work every time it has access to the Internet without requiring a persistent connection.
- The app now supports exporting Shapefiles with global coordinates.
Fixed
- Various fixes and improvements.
6.17
Added
- When connected to a receiver, you can now change its Bluetooth settings and manage its paired devices.
Fixed
6.16
Added
- We added the ability to delete custom coordinate systems.
Changed
- The app now shows more verbose warning messages if there is an issue with NTRIP credentials or the selected mountpoint.
Fixed
6.15
Added
- Exported CSV files now have additional columns containing geographic coordinates of the base.
Fixed
6.14
Added
- We added the ability to edit the name and description of existing survey projects.
- ReachView 3 now supports DXF export with the point name and height as text objects.
- The collector tool now makes a sound upon successful point collection.
- Added a new option for the Correction output—Local NTRIP.
Fixed
6.13
Added
- Exported CSV files now have an additional column containing the name of the coordinate system.
- Added the new transformation from RGF93 to NTF used for all CRSs based on NTF datum. These systems now require grid downloading.
- When connected to a receiver, you can now check its firmware version and available updates from inside the app.
Fixed
6.12
Added
- Added the datum transformation from ETRS89 to Belge 1972, used in Belgium.
- There are new vertical datums:
Brazil hgeoHNOR2020 height
,South Africa SAGEOID2010 height
, andBelgium HBG18 height
. - Added two vertical datums for France:
NGF-IGN69(RAF18B) height
andNGF-IGN69(RAF20) height
. - Coordinate systems without a projection are discontinued. This kind of systems has been removed from the list, and you can no longer create custom coordinate systems without specifying a projection. If you want to work in degrees, you may use the new Global CS option.
Fixed
- Increased the maximum collection time to 60 minutes.
- Position accuracy is now shown at all times, not just when averaging.
6.11
Fixed
6.10
Added
- Added support for French locale.
6.9
Added
- ReachView 3 now supports import and export of projects in Shapefile and DXF formats.
Fixed
6.8
Added
- Now, you can restore settings of your Reach from the app! To do this, select a corresponding menu item in the general settings section of your connected device.
- Meet new base shift feature, which allows applying a real-time shift to rover and base coordinates. To do this, open the corresponding wizard from the project info bottom sheet and select measured and known points.
Changed
- Now, devices with a Firmware version lower than 26 need to be updated to work with ReachView 3.
Fixed
6.7
Added
- We present you the ability to add points to a project by manually entering coordinates! While in the project, head to the points list, where you can now find a new control to add a point.
Fixed
6.6
Added
- Add new vertical CRSs for South Korea: “KNGEOID13 height”, “KNGEOID14 height”, and “KNGEOID18 height”.
- Added required transformations to ensure correct work of the surveying features on Hawaii.
- Meet the updated Base mode settings screen! Configure automatic base position averaging or enter exact geographic coordinates manually using the new UI.
Fixed
- Fix the 7-parameter transformation for the GGRS87 system (Greece) to work as expected.
6.5
Fixed
6.4
Added
- Now, you can restart and shut down your Reach from the app! To do this, tap on the connected device on the scanner or device settings screen and select a corresponding menu item.
Fixed
- Fixed an issue that could change points’ coordinates upon import if the project uses a custom CRS with Molodensky-Badekas transformation. If you encountered such behavior, we recommend creating a new project.
6.3
Added
- Added an ability to check base coordinates in the point info bottom sheet.
- Added new vertical datum, “Greece GREEKGEOID2010 height”, used in Greece.
- There are new horizontal CRSs for Greece: “HTRS07”, “HTRS07 / TM07”, “GGRS87”, and “GGRS87 / HEPOS”.
- Added a new “Baltic 1977 height” vertical datum for Georgia.
Fixed
6.2
Fixed
6.1
Fixed
6.0
Added
- We are proud to present the next major update of the app. Starting with this version, it is now possible to create custom coordinate systems by entering all needed parameters. To test the new functionality, head to the list of coordinate systems and hit the Plus button.
- We now support a new vertical datum, “Italy ITG2009 height”.
Changed
- All projects in Italy that use CRSs based on ED50 datum will utilize the transformation from ETRS89 to ED50 by “italy_ed50.tif” horizontal grid.
- All projects in Italy that use CRSs based on Monte Mario datum will utilize the transformation from ETRS89 to Monte Mario by “roma40.tif” horizontal grid.
Fixed
5.10
Fixed
5.9
Added
- Starting with Reach Firmware version 26, the app will save the highest PDOP value received during point collection. These values will be available in exported CSV files.
Fixed
5.8
Added
- Now, you can copy point coordinates and CRS info from the project's bottom sheets with a long tap on them.
- The Swiss vertical CRS “LHN95 height” is available once again! Be advised that projects created before the system’s temporary removal will ask you to re-download the geoid file.
- There is a new vertical datum “LN02 height” for Switzerland.
Changed
- Update metadata for a bunch of geoid files. It will affect projects based on “SRVN16 height”, “Latvia 2000 height”, “NN2000 height”, and “N60 height” vertical datums. Existing projects that use these vertical datums will ask you to re-download updated files upon opening.
Fixed
5.7
Fixed
5.6
Added
- The vertical CRS “DHHN2016 height” used in Germany is back! Please note that projects created before the system's temporary removal will ask you to re-download the geoid file.
- There are two new vertical datums for Hungary: “Hungary VITEL2014 height” and “Hungary EHT2014 height”.
- Added the transformation from ETRS89 to HD72 by “etrs2eov” horizontal grid, used in Hungary. Now, all CRSs based on HD72 datum will utilize this transformation.
Changed
- Updated distance formatting in the stakeout tool to make precise measurements over long distances easier.
Fixed
5.5
Added
- The averaging timestamps in exported CSV now contain a time zone offset. This will help to preserve information when importing a project in a different time zone.
- The EPSG list was updated in accordance with the EPSG v10.003.
- There are two new vertical datums for Croatia ("HVRS71 height") and France ("NGF-IGN69(RAF09) height").
Fixed
5.4
Added
- Exported CSV files now also contain geographic coordinates of points.
Fixed
- Fixed an issue that could cause the app to break the order of imported points randomly.
5.3
Changed
- Updated Russian, Spanish, and Turkish translations.
- Minor visual updates.
5.2
Added
- We added new vertical CRSs to support the legacy "GEOID12B" geoid. It covers the CONUS area and Alaska "NAVD88(GEOID12B) height", Virgin Island "VIVD09(GEOID12B) height" and Puerto Rico "PRVD02(GEOID12B) height".
Changed
- The status overview now shows the PDOP value with one decimal place.
- Slightly updated fonts in the status overview to make values more readable.
5.1
Added
- Correction output settings will now notify you if LoRa requires a higher air data rate. This feature covers the case when you enable LoRa, but the set air date rate doesn't suffice for configured RTCM3 messages. In such a case, the app will prompt you with a dialog describing the situation.
- The correction input settings screen and the status overview drawer will now show if your device is receiving corrections.
Changed
