RTK settings
RTK options#
Positioning mode#
  • Kinematic - most used positioning mode, assumes that the receiver is moving
  • Static - an assumption is made that Reach RS2 is static. Constraining the system helps to resolve ambiguities faster as well as produce measurements with higher precision
Elevation mask angle#
Satellites lower than set elevation will be excluded from the computation. The default setting is 15 degrees. Usually, satellites with a lower elevation provide too noisy measurements.
SNR mask#
Satellites with low SNR will be excluded from the computation. The default setting is 35.
GNSS selection#
Reach RS2 tracks GPS, GLONASS, GALILEO, QZSS, and BEIDOU satellite systems. The data can be logged with 1 Hz, 3 Hz, 5 Hz, or 10 Hz update rate.
All GNSS enabled at 5 Hz is our default recommendation.
