Placing the base
Figure 1
Figure 2
Ways to set the base
Base setup method | Accuracy | Requirement | Observation time | Processing time | Cost |
Manual, on a known point | same as the point | Known point | 0 min | Immediate, no processing required | Free |
Average single position | ~2.5 m | - | <5 min | Immediate, processing on Reach | Free |
RTK FIX position | 7mm+1mm/km | NTRIP stream from base <10km for RS/RS+ <60km for RS2/RS2+ | <5 min | Immediate, processing on Reach | Free/$$ depending on local provider |
RTK Float position | 1.0m | NTRIP stream from base <10km for RS/RS+ <60km for RS2/RS2+ | <15 min | Immediate, processing on Reach | Free/$$ depending on local provider |
Post-Processed Kinematic | 7mm+1mm/km | RINEX logs from base <30km for RS/RS+ <100 km for RS2/RS2+ | ~1 h | 15min on PC after log from reference station available, usually posted hourly | Free/$$ depending on local provider |
Precise Point Positioning | ~30cm for RS/RS+ ~1-2cm for RS2/RS2+ | - | ~4 h | In ~24h after submitting logs to NRCan online service | Free |
Manual
Android Keyboard Tech Tip
Pay attention and carefully place the base over a known point and measure the height of the antenna from the mark. It will help to avoid shifts from the absolute position and keep measurements accurate. Refer to Placing Reach RS2/RS2+ in the field for detailed instructions.
Average
Averaged single
Figure 3
Averaged FLOAT and FIX
Figure 4
Post-Processed Kinematics
With post processed kinematics technique you may determine base coordinates without real-time corrections with centimeter accuracy. You will need RINEX logs from the reference station in the area of 100 km and the raw data log from the receiver. The process will take you about 15 minutes to calculate the position of your base station using PPK in Static mode tutorial.
General steps:
Enable logging of raw data and record log for about an hour.
Export log with the collected data from Emlid Flow to your PC.
Refer to PPK in Static mode tutorial.
After you get the coordinates you may enter them manually in Base coordinates section. Comparing PPK position to the averaged position and applying corrections to the collected data is the way to compensate the shift shown in the example on figure 2.
General steps:
Enable logging of raw data and record log for a few hours.
Export log with the collected data from Emlid Flow to your mobile device or PC.
Upload the collected file to PPP service (for example, NRCan).
When placing your Reach RS2/RS2+ in the field, make sure your Reach device is placed precisely above the marked point on the tripod and leveled. If you are setting up base coordinates manually, you need to measure the antenna height offset. Follow the steps below:
Measure the distance between the mark and the bottom of your Reach (h on Figure 5).
Specify the measured distance in Emlid Flow. It will automatically calculate the antenna height.
Reach RS2/RS2+ antenna height
For Reach RS2/RS2+, the antenna height is the distance between the mark and the bottom of the receiver (h on Figure 5) plus the receiver's height to the antenna reference point (ARP) which is equal to 134 mm and automatically added by Emlid Flow.
Figure 5
When you securely placed Reach RS2/RS2+ over the mark, you are ready to set or determine its position.
