Placing the base
Figure 1
Figure 2
Ways to set the base
RTK FIX positionH:7mm+1ppm V:14mm+1ppmNTRIP stream from base <10km for RS/RS+ <60km for RS2/RS2+<5 minImmediate, processing on ReachFree/$$ depending on local provider
RTK Float position1.0mNTRIP stream from base <10km for RS/RS+ <60km for RS2/RS2+<15 minImmediate, processing on ReachFree/$$ depending on local provider
Static processingH:4mm+0.5ppm V:8mm+1ppmRINEX logs from base <30km for RS/RS+ <100 km for RS2/RS2+~1 h15min on PC after log from reference station available, usually posted hourlyFree/$$ depending on local provider
Precise Point Positioning~30cm for RS/RS+ ~1-2cm for RS2/RS2+-~4 hIn ~24h after submitting logs to NRCan online serviceFree
Manual
Android keyboard tech tip
Pay attention and carefully place the base over a known point and measure the height of the antenna from the mark. It will help to avoid shifts from the absolute position and keep measurements accurate. Refer to Placing Reach RS2/RS2+ in the field for detailed instructions.
Average
Averaged single
Figure 3
Averaged FLOAT and FIX
Figure 4
Static processing
General steps:
  1. Enable logging of raw data and record a log for about an hour.
  2. Export the log with the collected data from Emlid Flow to your PC.
  3. Refer to the Static processing tutorial. It will take you about 15 minutes to calculate the position of your base station.
  4. After you get the coordinates you may enter them manually in the Base coordinates section. Comparing the position obtained using Static processing to the averaged position and applying corrections to the collected data is the way to compensate the shift shown in the example in Figure 2.
General steps:
  2. Export log with the collected data from Emlid Flow to your mobile device or PC.
  3. Upload the collected file to PPP service (for example, NRCan).
  4. After you get the coordinates you may enter them manually in Base coordinates section.
When placing your Reach RS2/RS2+ in the field, make sure your Reach device is placed precisely above the marked point on the tripod and leveled. If you are setting up base coordinates manually, you need to measure the antenna height offset. Follow the steps below:
    Reach RS2/RS2+ antenna height
    For Reach RS2/RS2+, the antenna height is the distance between the mark and the bottom of the receiver (h on Figure 5) plus the receiver's height to the antenna reference point (ARP) which is equal to 134 mm and automatically added by Emlid Flow.
    Figure 5
When you securely placed Reach RS2/RS2+ over the mark, you are ready to set or determine its position.
