Power supply
How to power Reach M+¶
Emlid Reach M+ module can be powered using Micro-USB port or JST-GH ports. Power circuit is shared for all ports, so when you power the device over one port it will pass power to other ports.
Attention
Do not plug two power supplies at the same time as it may damage the device.
Power supply over USB¶
You can power Reach over Micro-USB cable using power supplies like:
- Power bank
- USB wall adapter
- Computer USB ports
Powering using JST-GH ports¶
Reach can be powered by providing 5 Volts to corresponding pins on any of the two JST-GH ports.
When Reach is powered over JST-GH port it will pass power to devices connected to Micro-USB OTG port such as flash drives, 3G\4G modems, USB radios etc.
